I’m at version 5.10.32 but I noticed that since a few updates ago I started getting an error on Failed Jobs on the health check window.
This is the error:
Stripe\Exception\InvalidArgumentException: api_key cannot be the empty string in /usr/share/nginx/invoiceninja/vendor/stripe/stripe-php/lib/BaseStripeClient.php:257
Stack trace:
#0 /usr/share/nginx/invoiceninja/vendor/stripe/stripe-php/lib/BaseStripeClient.php(70): Stripe\BaseStripeClient->validateConfig()
#1 /usr/share/nginx/invoiceninja/app/PaymentDrivers/StripePaymentDriver.php(123): Stripe\BaseStripeClient->__construct()
#2 /usr/share/nginx/invoiceninja/app/PaymentDrivers/Stripe/Jobs/StripeWebhook.php(68): App\PaymentDrivers\StripePaymentDriver->init()
#3 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(36): App\PaymentDrivers\Stripe\Jobs\StripeWebhook->handle()
#4 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Container/Util.php(41): Illuminate\Container\BoundMethod::Illuminate\Container{closure}()
#5 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(93): Illuminate\Container\Util::unwrapIfClosure()
#6 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(35): Illuminate\Container\BoundMethod::callBoundMethod()
#7 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Container/Container.php(662): Illuminate\Container\BoundMethod::call()
#8 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Bus/Dispatcher.php(128): Illuminate\Container\Container->call()
#9 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(144): Illuminate\Bus\Dispatcher->Illuminate\Bus{closure}()
#10 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(119): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline{closure}()
#11 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Bus/Dispatcher.php(132): Illuminate\Pipeline\Pipeline->then()
#12 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Queue/CallQueuedHandler.php(123): Illuminate\Bus\Dispatcher->dispatchNow()
#13 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(144): Illuminate\Queue\CallQueuedHandler->Illuminate\Queue{closure}()
#14 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(119): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline{closure}()
#15 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Queue/CallQueuedHandler.php(122): Illuminate\Pipeline\Pipeline->then()
#16 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Queue/CallQueuedHandler.php(70): Illuminate\Queue\CallQueuedHandler->dispatchThroughMiddleware()
#17 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Queue/Jobs/Job.php(102): Illuminate\Queue\CallQueuedHandler->call()
#18 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Queue/Worker.php(439): Illuminate\Queue\Jobs\Job->fire()
#19 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Queue/Worker.php(389): Illuminate\Queue\Worker->process()
#20 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Queue/Worker.php(176): Illuminate\Queue\Worker->runJob()
#21 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Queue/Console/WorkCommand.php(137): Illuminate\Queue\Worker->daemon()
#22 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Queue/Console/WorkCommand.php(120): Illuminate\Queue\Console\WorkCommand->runWorker()
#23 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(36): Illuminate\Queue\Console\WorkCommand->handle()
#24 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Container/Util.php(41): Illuminate\Container\BoundMethod::Illuminate\Container{closure}()
#25 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(93): Illuminate\Container\Util::unwrapIfClosure()
#26 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(35): Illuminate\Container\BoundMethod::callBoundMethod()
#27 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Container/Container.php(662): Illuminate\Container\BoundMethod::call()
#28 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Console/Command.php(211): Illuminate\Container\Container->call()
#29 /usr/share/nginx/invoiceninja/vendor/symfony/console/Command/Command.php(326): Illuminate\Console\Command->execute()
#30 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Console/Command.php(180): Symfony\Component\Console\Command\Command->run()
#31 /usr/share/nginx/invoiceninja/vendor/symfony/console/Application.php(1096): Illuminate\Console\Command->run()
#32 /usr/share/nginx/invoiceninja/vendor/symfony/console/Application.php(324): Symfony\Component\Console\Application->doRunCommand()
#33 /usr/share/nginx/invoiceninja/vendor/symfony/console/Application.php(175): Symfony\Component\Console\Application->doRun()
#34 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Console/Kernel.php(201): Symfony\Component\Console\Application->run()
#35 /usr/share/nginx/invoiceninja/artisan(35): Illuminate\Foundation\Console\Kernel->handle()
#36 {main}
I have two stripe gateways with different key one to proccess US payments and another for international payments. Each gateway is assigned to a different group in invoiceninja. Proccesing works fine I tested yesterday.
Any idea why the error?
