Facturation électronique
Bonjour, comment pensez-vous adapter invoice ninja à la facturation électronique ?
Merci
Yes, it’s supported. There’s more info here:
I am a French company using Invoice Ninja.
I see that Invoice Ninja now supports France through PEPPOL/Storecove, and that Storecove is now a French accredited “Plateforme Agréée”.
Can you confirm that the current Invoice Ninja integration with Storecove handles the full French e-invoicing requirements, including:
  • registration/routing through the French national directory,
  • domestic French B2B invoices through Storecove as PA,
  • invoice lifecycle statuses,
  • e-reporting to the French tax administration where required,
  • receiving French electronic invoices,
or does the current integration only provide PEPPOL transmission?
Sorry I’m not sure, I suggest sending an email to [email protected] to ask.
