Is there a way to export invoices into csv files so I can manually import to QBO if I need to?
You can export to CSV using the reports in v5.
Thanks for help. I was looking in import/export.
I was wondering if in the report options we could have line support in there so that basically it can spit out a csv that could be imported with everything from the invoice into a program like QBO.?
There’s an “Invoice Item” report, are any fields missing?
Yeah, That’s what I was looking for. Wish I would have noticed that earlier. I did a test with it and it looks like it gives all the proper line item support for importing invoices manually into QBO. I like this program more every day. Thanks!
