Hi…Anu option available to export all client details to excel or CSV format?
You can use the client report to export data to CSV.
In the future we plan to also support exporting in the settings.
I am able to export a list of my customers and their information in the report section.
Is there a way to only export active clients? Not achived ones. So I could use this list to update our mailing list once in a while?
Thank you.
Which app are you using?
In the desktop app you can add the ‘Record State’ column to the client report and filter it to active records.
