Is there another way to export all Data? The Button in “Import/Export” does not work. It says i will get an email but there is no mail.
Are there any errors in storage/logs? cc @david
It’s also possible to export data as CSV using the reports.
you may want to check your logs. The system dispatches a job to create the zip file and then sends an email. you may also want to check public/storage/backups if the file exists.
