Would be great to be able to input expenses tax amount.
Regards
This is supported in v5, in can be enabled in the expense settings
Are you sure? I dont see this option, I only see:
-Should be invoiced
-Mark paid
-Add documents to invoice
-Category management
But nothing about taxes.
Regards
Have you enabled line item taxes on Settings > Tax Rates?
I see, but doing so, it will also add tax columns to item invoices. Tha´ts the only whay I can achieve this?
Yes, the features are connected. If you an invoice an expense the app needs to be able to map the line item taxes.
I see, ok thank you.
