Expenses Categories - Colours, View, Import
I’ve just gone through the painful process of extracting out of Freshbooks and into IN. While getting to grips with IN I started entering Expenses and noticed three things :
1 - You cannot import expense categories
2 - I’ve set up colours for various categories (e.g. all COGS are red to remind me to on bill them) but those colours are never used anywhere. I think having the colours used in the default expenses view would make seeing what type of expenses are in the list much easier.
3 - The expenses category is not displayed in the expenses view and there seems no way to add it as a column. It would really help to see the category as there are some vendors etc we get things off, some of which is COGS, some of it is internal expenses. Seeing the colour and category would help.
Thanks for the great product.
Since you’re on the hosted platform I suggest sending an email to [email protected] to share your feedback.
Note: if you’re using the web app you may want to compare with the desktop app.
