Hi Hillel,
is there any REST API for expenses or am I trying something that will never work?
$expense = new stdClass;
$expense->vendor_id=21; // Stripe
$expense->amount=number_format((float)($fee / 100),2);
$expense->public_notes="Frais de transaction du payment processor pour le transfert : $transfert_id";
$response = sendRequestInvoiceNinja(INVOICE_NINJA_TOKEN,'expenses', $expense, "POST");
if (!function_exists("sendRequestInvoiceNinja")) {
function sendRequestInvoiceNinja($token, $url, $data, $type = 'POST')
$url = "https://facturation.xxxxxxxxx.com/api/v1/" . $url;
$data = json_encode($data);
$curl = curl_init();
$opts = [ CURLOPT_URL => $url,
CURLOPT_RETURNTRANSFER => true,
CURLOPT_CUSTOMREQUEST => $type,
CURLOPT_POST => $type === 'POST' ? 1 : 0,
CURLOPT_POSTFIELDS => $data,
CURLOPT_HTTPHEADER => [
'Content-Type: application/json',
'Content-Length: ' . strlen($data),
'X-Ninja-Token: '.$token,
curl_setopt_array($curl, $opts);
$response = curl_exec($curl);
//die($response);
curl_close($curl);
return json_decode($response);
I have added the sendRequestInvoiceNinja function but the problem is not there, it’s working fine with all the other API.
Am I missing an essential parameter?
Best regards,
