I updated from v5.1.34 to v5.1.42, then an existing account could not login so I tried to REMOVE user but i got an error 412: Invalid Password when I didnt get the option to enter my admin password
so I used DELETE to remove the user, then I get to enter password…so I am able to remove user.
now I re-add the user same email address, I was expecting to create a password for this user but none. Rather, an email was sent to user to CONFIRM EMAIL ADDRESS, I clicked that link, hopping it will ask me to set a password but nothing.
I have noticed, UPDATING or UPGRADING from one version to the other is a matter of replacing the existing files in the document root of the invoice app, and THEN IT GOES BUT INITIATL SETUP AGAIN…asking for database user etc…Shouldn’t updates/upgrades just stay active without having to act like A FRESH NEW INSTALL…
for me, I use the same database credentials as the previous/existing version…and then at the last stage where form asks to creat admin user name and paswrd, I intentionally put same email and a different password from the existing version…when its done and I go to login…the new passwrd i put does not work, the old password works…so now i know most of the settings from the old version still there because it same database, therefore existing user account looses its password and then you are forced to remove that user, re-add same user and cant get to set a passwrd again.
Please when are you adding Canadian banks to the list of payment gateway?? We cant benefit from it without out banks added. CIBC, BANK OF MONTREAL, SCOTTIA BANK, TD CANADA BANK, ROYAL BANK etc.
also, can you please add a salutation option to the CLIENT FORM so we get like MR. JOHN SMITH.
QUESTION: Can we update without having to go through the initial start like its a new install?
Can you also ALLOW THE OPTION for a admin to ASSIGN multiple company account to a specific user…or I can add same user to the intended company accounts?
can you exclude extra zeros from being added to item’s QUANTITY figure…once you put 3 as quantity on invoice, it becomes 3.00
and can there a 2nd level of authority where by I assign a user to edit stuff, user can change an amount on an existing invoice or like a discount and after saving changes, it needs approval from main admin
412 invalid password error seems to occur too often when you try to save save any changes
so if you delete because you forgot their passwrd or passwrd dont after update you cannot re-add the user by same email address again
A PAID INVOICE doesn’t get SENT to the client with “PAID”…or when you want to download and save as pdf, it doesnt STATE or show “PAID” just as it says PAID in the backend
