Hi there,
Recently updated Invoice Ninja to v4.3.1 and now I am receiving this error when trying to access online payments or invoice settings:
“Whoops, looks like something went wrong.”
I can access the laravel-error.log file if that helps.
Any help would be appreciated. Thanks!
Mike
What do you see on /update (or /public/update)
Hi Hillel,
Thanks for the quick response. Neither of those folders seem to exist.
Please view it in your browser, yousite.com/update
Aaah sorry I get you. This is the message displayed on /public/update/
is_executable(): open_basedir restriction in effect. File(/opt/alt/php71/usr/bin/php) is not within the allowed path(s): (/home/iseardmedia:/usr/lib/php:/usr/php4/lib/php:/usr/local/lib/php:/usr/local/php4/lib/php:/tmp)
You’ll need to either temporarily modify your open_basedir settings or run the update from the command line.
http://docs.invoiceninja.com/en/latest/update.html
OK that seems to have fixed the problem. Is it not recommended to leave the modification to the open_basedir setting?
Thanks again for the quick support.
