Have you inspected the logs in storage/logs/laravel.log for any errors?
Yes, and l it is strange - laravel.log has no new entries
Describe the bug
Markups in documents (like ###) are not parsed anymore. Update (and forced update) give this error (APP_DEBUG is true): 500: Internal Server Error • The command "ninja:design" does not exist.
Steps To Reproduce
Update Invoice Ninja from the Flutter web page
Error appears, but app is updated and it works (except markups)
Expected Behavior
After update I expect no errors and markups working.
Additional context
I try composer i -o --no-dev and php artisan optimize and also force install again, but markups still do not work.
Screenshots
Logs
This is strange - there are no new entry or errors in laravel.log
Error is shown only at the end of the update process and nowhere in logs
I see that bug #10587 is closed as fixed. I’ve made update, and then force update to the latest version (v5.11.31-C172) and now error after update is gone.
But the ### markups still do not work. Maybe I miss something?
There isn’t any more detailed errors showing up anywhere but nothing has changed with my webserver or its config, I’ve only been using the self updater and a few versions back this Error 500 started appearing. In this update more information is presented as "the command “ninja:design” does not exist.
I haven’t been doing anything with markups. It should be noted that the update does complete again, but throws this error at the end.
Thanks, this last error is a known one which wont appear in the next release.
One this to help debug this, when you are performing the self upder, open the browser console (F12) and watch the timer, if it exceeds 30 seconds, my guess is the browser and server are disconnecting, and this is the error you are seeing.
