Version
v5.10.57
Environment:
Docker
Checklist
- Can you replicate the issue on our v5 demo site https://demo.invoiceninja.com or Invoice Ninja? NO
- Have you searched existing issues? yes
- Have you inspected the logs in storage/logs/laravel.log for any errors? yes
Describe the bug
Steps To Reproduce
Go into application
invoices
pick any invoice and click clone to invoice. It will bring up a new invoice in which I fill out the required fields and click save. I then get a "something went wrong" error
Expected Behavior
I expected the application to save the invoice so I can then email and/or print it
Additional context
none
Screenshots
Logs
[2024-11-26 21:20:37] production.ERROR: SQLSTATE[23000]: Integrity constraint violation: 1048 Column ‘custom_value1’ cannot be null (Connection: mysql, SQL: insert into invoices
(status_id
, number
, discount
, is_amount_discount
, po_number
, footer
, terms
, public_notes
, `private_note
at /var/www/app/vendor/laravel/framework/src/Illuminate/Database/Connection.php:825)
#0 /var/www/app/vendor/laravel/framework/src/Illuminate/Database/Connection.php(779): Illuminate\Database\Connection->runQueryCallback()
#1 /var/www/app/vendor/laravel/framework/src/Illuminate/Database/MySqlConnection.php(42): Illuminate\Database\Connection->run()
#2 /var/www/app/vendor/laravel/framework/src/Illuminate/Database/Query/Processors/MySqlProcessor.php(35): Illuminate\Database\MySqlConnection->insert()
#3 /var/www/app/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(3799): Illuminate\Database\Query\Processors\MySqlProcessor->processInsertGetId()
#4 /var/www/app/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Builder.php(2049): Illuminate\Database\Query\Builder->insertGetId()
#5 /var/www/app/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Model.php(1358): Illuminate\Database\Eloquent\Builder->__call()
#6 /var/www/app/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Model.php(1323): Illuminate\Database\Eloquent\Model->insertAndSetId()
#7 /var/www/app/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Model.php(1162): Illuminate\Database\Eloquent\Model->performInsert()
#8 /var/www/app/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Model.php(1128): Illuminate\Database\Eloquent\Model->save()
#9 /var/www/app/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Concerns/HasEvents.php(454): Illuminate\Database\Eloquent\Model->Illuminate\Database\Eloquent\{closure}()
#10 /var/www/app/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Model.php(1128): Illuminate\Database\Eloquent\Model::withoutEvents()
#11 /var/www/app/app/Repositories/BaseRepository.php(203): Illuminate\Database\Eloquent\Model->saveQuietly()
#12 /var/www/app/app/Repositories/InvoiceRepository.php(35): App\Repositories\BaseRepository->alternativeSave()
#13 /var/www/app/app/Http/Controllers/InvoiceController.php(230): App\Repositories\InvoiceRepository->save()
#14 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/Controller.php(54): App\Http\Controllers\InvoiceController->store()
#15 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/ControllerDispatcher.php(43): Illuminate\Routing\Controller->callAction()
#16 /var/www/app/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Tracing/Routing/TracingControllerDispatcherTracing.php(21): Illuminate\Routing\ControllerDispatcher->dispatch()
#17 /var/www/app/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Tracing/Routing/TracingRoutingDispatcher.php(18): Sentry\Laravel\Tracing\Routing\TracingControllerDispatcherTracing->Sentry\Laravel\Tracing\Routing\{closure}()
#18 /var/www/app/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Tracing/Routing/TracingControllerDispatcherTracing.php(20): Sentry\Laravel\Tracing\Routing\TracingRoutingDispatcher->wrapRouteDispatch()
#19 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/Route.php(264): Sentry\Laravel\Tracing\Routing\TracingControllerDispatcherTracing->dispatch()
#20 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/Route.php(210): Illuminate\Routing\Route->runController()
#21 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/Router.php(808): Illuminate\Routing\Route->run()
#22 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(144): Illuminate\Routing\Router->Illuminate\Routing\{closure}()
#23 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/Middleware/ThrottleRequests.php(124): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#24 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/Middleware/ThrottleRequests.php(89): Illuminate\Routing\Middleware\ThrottleRequests->handleRequestUsingNamedLimiter()
#25 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Illuminate\Routing\Middleware\ThrottleRequests->handle()
#26 /var/www/app/app/Http/Middleware/QueryLogging.php(39): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#27 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): App\Http\Middleware\QueryLogging->handle()
#28 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/Middleware/SubstituteBindings.php(51): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#29 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Illuminate\Routing\Middleware\SubstituteBindings->handle()
#30 /var/www/app/app/Http/Middleware/Locale.php(95): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#31 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): App\Http\Middleware\Locale->handle()
#32 /var/www/app/app/Http/Middleware/TokenAuth.php(102): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#33 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): App\Http\Middleware\TokenAuth->handle()
#34 /var/www/app/app/Http/Middleware/SetDb.php(40): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#35 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): App\Http\Middleware\SetDb->handle()
#36 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(119): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#37 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/Router.php(807): Illuminate\Pipeline\Pipeline->then()
#38 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/Router.php(786): Illuminate\Routing\Router->runRouteWithinStack()
#39 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/Router.php(750): Illuminate\Routing\Router->runRoute()
#40 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/Router.php(739): Illuminate\Routing\Router->dispatchToRoute()
#41 /var/www/app/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(201): Illuminate\Routing\Router->dispatch()
#42 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(144): Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}()
#43 /var/www/app/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/FlushEventsMiddleware.php(13): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#44 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Sentry\Laravel\Http\FlushEventsMiddleware->handle()
#45 /var/www/app/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/SetRequestIpMiddleware.php(45): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#46 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Sentry\Laravel\Http\SetRequestIpMiddleware->handle()
#47 /var/www/app/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/SetRequestMiddleware.php(31): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#48 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Sentry\Laravel\Http\SetRequestMiddleware->handle()
#49 /var/www/app/vendor/livewire/livewire/src/Features/SupportDisablingBackButtonCache/DisableBackButtonCacheMiddleware.php(19): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#50 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Livewire\Features\SupportDisablingBackButtonCache\DisableBackButtonCacheMiddleware->handle()
#51 /var/www/app/app/Http/Middleware/Cors.php(24): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#52 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): App\Http\Middleware\Cors->handle()
#53 /var/www/app/vendor/laravel/framework/src/Illuminate/Http/Middleware/TrustProxies.php(58): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#54 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Illuminate\Http\Middleware\TrustProxies->handle()
#55 /var/www/app/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#56 /var/www/app/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ConvertEmptyStringsToNull.php(31): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle()
#57 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Illuminate\Foundation\Http\Middleware\ConvertEmptyStringsToNull->handle()
#58 /var/www/app/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#59 /var/www/app/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TrimStrings.php(51): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle()
#60 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Illuminate\Foundation\Http\Middleware\TrimStrings->handle()
#61 /var/www/app/vendor/laravel/framework/src/Illuminate/Http/Middleware/ValidatePostSize.php(27): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#62 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Illuminate\Http\Middleware\ValidatePostSize->handle()
#63 /var/www/app/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/PreventRequestsDuringMaintenance.php(110): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#64 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Illuminate\Foundation\Http\Middleware\PreventRequestsDuringMaintenance->handle()
#65 /var/www/app/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Tracing/Middleware.php(79): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#66 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Sentry\Laravel\Tracing\Middleware->handle()
#67 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(119): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#68 /var/www/app/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(176): Illuminate\Pipeline\Pipeline->then()
#69 /var/www/app/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(145): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter()
#70 /var/www/app/public/index.php(56): Illuminate\Foundation\Http\Kernel->handle()
#71 {main}
[previous exception] [object] (PDOException(code: 23000): SQLSTATE[23000]: Integrity constraint violation: 1048 Column ‘custom_value1’ cannot be null at /var/www/app/vendor/laravel/framework/src/Illuminate/Database/MySqlConnection.php:53)
#0 /var/www/app/vendor/laravel/framework/src/Illuminate/Database/MySqlConnection.php(53): PDOStatement->execute()
#1 /var/www/app/vendor/laravel/framework/src/Illuminate/Database/Connection.php(812): Illuminate\Database\MySqlConnection->Illuminate\Database\{closure}()
#2 /var/www/app/vendor/laravel/framework/src/Illuminate/Database/Connection.php(779): Illuminate\Database\Connection->runQueryCallback()
#3 /var/www/app/vendor/laravel/framework/src/Illuminate/Database/MySqlConnection.php(42): Illuminate\Database\Connection->run()
#4 /var/www/app/vendor/laravel/framework/src/Illuminate/Database/Query/Processors/MySqlProcessor.php(35): Illuminate\Database\MySqlConnection->insert()
#5 /var/www/app/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(3799): Illuminate\Database\Query\Processors\MySqlProcessor->processInsertGetId()
#6 /var/www/app/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Builder.php(2049): Illuminate\Database\Query\Builder->insertGetId()
#7 /var/www/app/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Model.php(1358): Illuminate\Database\Eloquent\Builder->__call()
#8 /var/www/app/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Model.php(1323): Illuminate\Database\Eloquent\Model->insertAndSetId()
#9 /var/www/app/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Model.php(1162): Illuminate\Database\Eloquent\Model->performInsert()
#10 /var/www/app/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Model.php(1128): Illuminate\Database\Eloquent\Model->save()
#11 /var/www/app/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Concerns/HasEvents.php(454): Illuminate\Database\Eloquent\Model->Illuminate\Database\Eloquent\{closure}()
#12 /var/www/app/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Model.php(1128): Illuminate\Database\Eloquent\Model::withoutEvents()
#13 /var/www/app/app/Repositories/BaseRepository.php(203): Illuminate\Database\Eloquent\Model->saveQuietly()
#14 /var/www/app/app/Repositories/InvoiceRepository.php(35): App\Repositories\BaseRepository->alternativeSave()
#15 /var/www/app/app/Http/Controllers/InvoiceController.php(230): App\Repositories\InvoiceRepository->save()
#16 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/Controller.php(54): App\Http\Controllers\InvoiceController->store()
#17 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/ControllerDispatcher.php(43): Illuminate\Routing\Controller->callAction()
#18 /var/www/app/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Tracing/Routing/TracingControllerDispatcherTracing.php(21): Illuminate\Routing\ControllerDispatcher->dispatch()
#19 /var/www/app/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Tracing/Routing/TracingRoutingDispatcher.php(18): Sentry\Laravel\Tracing\Routing\TracingControllerDispatcherTracing->Sentry\Laravel\Tracing\Routing\{closure}()
#20 /var/www/app/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Tracing/Routing/TracingControllerDispatcherTracing.php(20): Sentry\Laravel\Tracing\Routing\TracingRoutingDispatcher->wrapRouteDispatch()
#21 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/Route.php(264): Sentry\Laravel\Tracing\Routing\TracingControllerDispatcherTracing->dispatch()
#22 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/Route.php(210): Illuminate\Routing\Route->runController()
#23 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/Router.php(808): Illuminate\Routing\Route->run()
#24 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(144): Illuminate\Routing\Router->Illuminate\Routing\{closure}()
#25 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/Middleware/ThrottleRequests.php(124): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#26 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/Middleware/ThrottleRequests.php(89): Illuminate\Routing\Middleware\ThrottleRequests->handleRequestUsingNamedLimiter()
#27 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Illuminate\Routing\Middleware\ThrottleRequests->handle()
#28 /var/www/app/app/Http/Middleware/QueryLogging.php(39): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#29 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): App\Http\Middleware\QueryLogging->handle()
#30 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/Middleware/SubstituteBindings.php(51): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#31 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Illuminate\Routing\Middleware\SubstituteBindings->handle()
#32 /var/www/app/app/Http/Middleware/Locale.php(95): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#33 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): App\Http\Middleware\Locale->handle()
#34 /var/www/app/app/Http/Middleware/TokenAuth.php(102): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#35 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): App\Http\Middleware\TokenAuth->handle()
#36 /var/www/app/app/Http/Middleware/SetDb.php(40): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#37 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): App\Http\Middleware\SetDb->handle()
#38 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(119): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#39 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/Router.php(807): Illuminate\Pipeline\Pipeline->then()
#40 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/Router.php(786): Illuminate\Routing\Router->runRouteWithinStack()
#41 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/Router.php(750): Illuminate\Routing\Router->runRoute()
#42 /var/www/app/vendor/laravel/framework/src/Illuminate/Routing/Router.php(739): Illuminate\Routing\Router->dispatchToRoute()
#43 /var/www/app/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(201): Illuminate\Routing\Router->dispatch()
#44 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(144): Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}()
#45 /var/www/app/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/FlushEventsMiddleware.php(13): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#46 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Sentry\Laravel\Http\FlushEventsMiddleware->handle()
#47 /var/www/app/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/SetRequestIpMiddleware.php(45): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#48 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Sentry\Laravel\Http\SetRequestIpMiddleware->handle()
#49 /var/www/app/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/SetRequestMiddleware.php(31): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#50 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Sentry\Laravel\Http\SetRequestMiddleware->handle()
#51 /var/www/app/vendor/livewire/livewire/src/Features/SupportDisablingBackButtonCache/DisableBackButtonCacheMiddleware.php(19): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#52 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Livewire\Features\SupportDisablingBackButtonCache\DisableBackButtonCacheMiddleware->handle()
#53 /var/www/app/app/Http/Middleware/Cors.php(24): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#54 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): App\Http\Middleware\Cors->handle()
#55 /var/www/app/vendor/laravel/framework/src/Illuminate/Http/Middleware/TrustProxies.php(58): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#56 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Illuminate\Http\Middleware\TrustProxies->handle()
#57 /var/www/app/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#58 /var/www/app/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ConvertEmptyStringsToNull.php(31): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle()
#59 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Illuminate\Foundation\Http\Middleware\ConvertEmptyStringsToNull->handle()
#60 /var/www/app/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#61 /var/www/app/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TrimStrings.php(51): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle()
#62 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Illuminate\Foundation\Http\Middleware\TrimStrings->handle()
#63 /var/www/app/vendor/laravel/framework/src/Illuminate/Http/Middleware/ValidatePostSize.php(27): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#64 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Illuminate\Http\Middleware\ValidatePostSize->handle()
#65 /var/www/app/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/PreventRequestsDuringMaintenance.php(110): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#66 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Illuminate\Foundation\Http\Middleware\PreventRequestsDuringMaintenance->handle()
#67 /var/www/app/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Tracing/Middleware.php(79): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#68 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Sentry\Laravel\Tracing\Middleware->handle()
#69 /var/www/app/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(119): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#70 /var/www/app/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(176): Illuminate\Pipeline\Pipeline->then()
#71 /var/www/app/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(145): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter()
#72 /var/www/app/public/index.php(56): Illuminate\Foundation\Http\Kernel->handle()
#73 {main}
Please help so I can bill my client
