I just updated my self-hosted ninja with the help of softaculous. I get 2 checkboxes for accepting the terms. When I try to accept them, I get the folowing errors.
What is the problem?
Ninja version 4.4.3
PHP 7.0.30
Whoops, looks like something went wrong.
(3/3) QueryException
SQLSTATE[42S22]: Column not found: 1054 Unknown column 'accepted_terms_version' in 'field list' (SQL: update <code>users</code> set <code>updated_at</code> = 2018-05-31 07:35:05, <code>accepted_terms_version</code> = 1.0.1, <code>accepted_terms_timestamp</code> = 2018-05-31 07:35:05, <code>accepted_terms_ip</code> = 78.20.45.194 where <code>id</code> = 1)
in Connection.php (line 647)
at Connection->runQueryCallback('update <code>users</code> set <code>updated_at</code> = ?, <code>accepted_terms_version</code> = ?, <code>accepted_terms_timestamp</code> = ?, <code>accepted_terms_ip</code> = ? where <code>id</code> = ?', array('2018-05-31 07:35:05', '1.0.1', '2018-05-31 07:35:05', '78.20.45.194', 1), object(Closure))
in Connection.php (line 607)
at Connection->run('update <code>users</code> set <code>updated_at</code> = ?, <code>accepted_terms_version</code> = ?, <code>accepted_terms_timestamp</code> = ?, <code>accepted_terms_ip</code> = ? where <code>id</code> = ?', array('2018-05-31 07:35:05', '1.0.1', '2018-05-31 07:35:05', '78.20.45.194', 1), object(Closure))
in Connection.php (line 477)
at Connection->affectingStatement('update <code>users</code> set <code>updated_at</code> = ?, <code>accepted_terms_version</code> = ?, <code>accepted_terms_timestamp</code> = ?, <code>accepted_terms_ip</code> = ? where <code>id</code> = ?', array('2018-05-31 07:35:05', '1.0.1', '2018-05-31 07:35:05', '78.20.45.194', 1))
in Connection.php (line 416)
at Connection->update('update <code>users</code> set <code>updated_at</code> = ?, <code>accepted_terms_version</code> = ?, <code>accepted_terms_timestamp</code> = ?, <code>accepted_terms_ip</code> = ? where <code>id</code> = ?', array('2018-05-31 07:35:05', '1.0.1', '2018-05-31 07:35:05', '78.20.45.194', 1))
in Builder.php (line 2147)
at Builder->update(array('updated_at' => '2018-05-31 07:35:05', 'accepted_terms_version' => '1.0.1', 'accepted_terms_timestamp' => '2018-05-31 07:35:05', 'accepted_terms_ip' => '78.20.45.194'))
in Builder.php (line 759)
in Model.php (line 595)
at Model->performUpdate(object(Builder))
in Model.php (line 515)
at Model->save()
in UserController.php (line 403)
at UserController->acceptTerms()
at call_user_func_array(array(object(UserController), 'acceptTerms'), array())
in Controller.php (line 55)
at Controller->callAction('acceptTerms', array())
in ControllerDispatcher.php (line 44)
at ControllerDispatcher->dispatch(object(Route), object(UserController), 'acceptTerms')
in Route.php (line 203)
at Route->runController()
in Route.php (line 160)
at Route->run()
in Router.php (line 572)
at Router->Illuminate\Routing\{closure}(object(Request))
in Pipeline.php (line 30)
at Pipeline->Illuminate\Routing\{closure}(object(Request))
in Authenticate.php (line 122)
at Authenticate->handle(object(Request), object(Closure), 'user')
in Pipeline.php (line 148)
at Pipeline->Illuminate\Pipeline\{closure}(object(Request))
in Pipeline.php (line 53)
in DatabaseLookup.php (line 21)
at DatabaseLookup->handle(object(Request), object(Closure), 'user')
in StartupCheck.php (line 234)
at StartupCheck->handle(object(Request), object(Closure))
in QueryLogging.php (line 32)
at QueryLogging->handle(object(Request), object(Closure))
in DuplicateSubmissionCheck.php (line 41)
at DuplicateSubmissionCheck->handle(object(Request), object(Closure))
in TransformsRequest.php (line 30)
at TransformsRequest->handle(object(Request), object(Closure))
in VerifyCsrfToken.php (line 65)
at VerifyCsrfToken->handle(object(Request), object(Closure))
in VerifyCsrfToken.php (line 44)
in ShareErrorsFromSession.php (line 49)
at ShareErrorsFromSession->handle(object(Request), object(Closure))
in StartSession.php (line 64)
at StartSession->handle(object(Request), object(Closure))
in AddQueuedCookiesToResponse.php (line 37)
at AddQueuedCookiesToResponse->handle(object(Request), object(Closure))
in EncryptCookies.php (line 59)
at EncryptCookies->handle(object(Request), object(Closure))
in Pipeline.php (line 102)
at Pipeline->then(object(Closure))
in Router.php (line 574)
at Router->runRouteWithinStack(object(Route), object(Request))
in Router.php (line 533)
at Router->dispatchToRoute(object(Request))
in Router.php (line 511)
at Router->dispatch(object(Request))
in Kernel.php (line 176)
at Kernel->Illuminate\Foundation\Http\{closure}(object(Request))
in Debugbar.php (line 51)
at Debugbar->handle(object(Request), object(Closure))
in CheckForMaintenanceMode.php (line 46)
at CheckForMaintenanceMode->handle(object(Request), object(Closure))
in HandlePreflight.php (line 46)
at HandlePreflight->handle(object(Request), object(Closure))
in Kernel.php (line 151)
at Kernel->sendRequestThroughRouter(object(Request))
in Kernel.php (line 116)
at Kernel->handle(object(Request))
in index.php (line 51)
(2/3) PDOException
in PDOConnection.php (line 79)
at PDOConnection->prepare('update <code>users</code> set <code>updated_at</code> = ?, <code>accepted_terms_version</code> = ?, <code>accepted_terms_timestamp</code> = ?, <code>accepted_terms_ip</code> = ? where <code>id</code> = ?')
in Connection.php (line 470)
at Connection->Illuminate\Database\{closure}('update <code>users</code> set <code>updated_at</code> = ?, <code>accepted_terms_version</code> = ?, <code>accepted_terms_timestamp</code> = ?, <code>accepted_terms_ip</code> = ? where <code>id</code> = ?', array('2018-05-31 07:35:05', '1.0.1', '2018-05-31 07:35:05', '78.20.45.194', 1))
in Connection.php (line 640)
at Model->save()
at Route->run()
(1/3) PDOException
in PDOConnection.php (line 77)
at PDO->prepare('update <code>users</code> set <code>updated_at</code> = ?, <code>accepted_terms_version</code> = ?, <code>accepted_terms_timestamp</code> = ?, <code>accepted_terms_ip</code> = ? where <code>id</code> = ?', array())
at Model->save()
at Route->run()
