Hello.
I have the “Update available” triangle bottom left
Clicked UPDATE NOW
Entered the password, and after a small delay I get:
My php.ini is set a file limit of 512M
Any advice or help is always appreciated
Kind regards
Dj
Hello.
Clicked UPDATE NOW
Kind regards
Dj
It could be a permissions issue, it may help to run:
sudo chown -R www-data:www-data /var/www/html
sudo find ./ -type d -exec chmod 755 {} \;
https://invoiceninja.github.io/docs/self-host-installation/#file-permissions
Thank you very much…
I will give that a try later on. I’ll have a quick read of the link first.
Best wishes
Dj
