I am having problems migrating my selfhosted v4 instance to v5.
I am running the latest version of v4 on ubuntu 20.04 with php 7.3
I am running the latest v5 on ubuntu 20.04 with with php8
Both instances run behind a reverse proxy container that has valid lets encrypt certs
Both instances have nginx configured on the ubuntu image with 80/443 and self singed certs (the reverse proxy container points to this on 443)
I have followed all the instructions and have the same email password combination created on the v5 instance.
When running the migrate i get all the way to the last step and then get the error Oops, something went wrong. Migration can't be processed at the moment. Please checks the logs.
In the logs on the v4 instance i get the following
[2021-07-01 23:36:03] production.ERROR: ***Unirest\Exception*** [0] : /var/www/invoiceninja/vendor/mashape/unirest-php/src/Unirest/Request.php [Line 476] => SSL certificate problem: self signed certificate {"context":"PHP","user_id":1,"account_id":1,"user_name":"USER","method":"POST","user_agent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/91.0.4472.114 Safari/537.36","locale":"en","ip":"10.0.0.38","count":5,"is_console":"no","is_api":"no","db_server":"mysql","url":"migration/auth"} []
the migration is going via the reverse proxy container as that is where the DNS points to. I have also tried going direct but that fails at an earlier step.
there is also a stacktrace.log
2021-07-01 11:36:03 SSL certificate problem: self signed certificate: #0 /var/www/invoiceninja/vendor/mashape/unirest-php/src/Unirest/Request.php(292): Unirest\Request::send('POST', 'https://10.0.0....', '{"email":"josh@...', Array, NULL, NULL)
#1 /var/www/invoiceninja/app/Services/Migration/AuthService.php(56): Unirest\Request::post('https://10.0.0....', Array, '{"email":"josh@...')
#2 /var/www/invoiceninja/app/Http/Controllers/Migration/StepsController.php(137): App\Services\Migration\AuthService->start()
#3 [internal function]: App\Http\Controllers\Migration\StepsController->handleAuth(Object(App\Http\Requests\MigrationAuthRequest))
#4 /var/www/invoiceninja/vendor/turbo124/framework/src/Illuminate/Routing/Controller.php(54): call_user_func_array(Array, Array)
#5 /var/www/invoiceninja/vendor/turbo124/framework/src/Illuminate/Routing/ControllerDispatcher.php(45): Illuminate\Routing\Controller->callAction('handleAuth', Array)
#6 /var/www/invoiceninja/vendor/turbo124/framework/src/Illuminate/Routing/Route.php(212): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(App\Http\Controllers\Migration\StepsController), 'handleAuth')
#7 /var/www/invoiceninja/vendor/turbo124/framework/src/Illuminate/Routing/Route.php(169): Illuminate\Routing\Route->runController()
#8 /var/www/invoiceninja/vendor/turbo124/framework/src/Illuminate/Routing/Router.php(658): Illuminate\Routing\Route->run()
#9 /var/www/invoiceninja/vendor/turbo124/framework/src/Illuminate/Routing/Pipeline.php(30): Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request))
#10 /var/www/invoiceninja/app/Http/Middleware/EligibleForMigration.php(19): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request))
#11 /var/www/invoiceninja/vendor/turbo124/framework/src/Illuminate/Pipeline/Pipeline.php(149): App\Http\Middleware\EligibleForMigration->handle(Object(Illuminate\Http\Request), Object(Closure))
#12 /var/www/invoiceninja/vendor/turbo124/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#13 /var/www/invoiceninja/app/Http/Middleware/Authenticate.php(122): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request))
#14 /var/www/invoiceninja/vendor/turbo124/framework/src/Illuminate/Pipeline/Pipeline.php(149): App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), 'user')
#15 /var/www/invoiceninja/vendor/turbo124/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#16 /var/www/invoiceninja/app/Http/Middleware/DatabaseLookup.php(21): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request))
#17 /var/www/invoiceninja/vendor/turbo124/framework/src/Illuminate/Pipeline/Pipeline.php(149): App\Http\Middleware\DatabaseLookup->handle(Object(Illuminate\Http\Request), Object(Closure), 'user')
#18 /var/www/invoiceninja/vendor/turbo124/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#19 /var/www/invoiceninja/app/Http/Middleware/StartupCheck.php(241): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request))
#20 /var/www/invoiceninja/vendor/turbo124/framework/src/Illuminate/Pipeline/Pipeline.php(149): App\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure))
#21 /var/www/invoiceninja/vendor/turbo124/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#22 /var/www/invoiceninja/app/Http/Middleware/QueryLogging.php(32): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request))
#23 /var/www/invoiceninja/vendor/turbo124/framework/src/Illuminate/Pipeline/Pipeline.php(149): App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure))
#24 /var/www/invoiceninja/vendor/turbo124/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#25 /var/www/invoiceninja/app/Http/Middleware/DuplicateSubmissionCheck.php(41): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request))
#26 /var/www/invoiceninja/vendor/turbo124/framework/src/Illuminate/Pipeline/Pipeline.php(149): App\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure))
#27 /var/www/invoiceninja/vendor/turbo124/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#28 /var/www/invoiceninja/vendor/turbo124/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(30): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request))
#29 /var/www/invoiceninja/vendor/turbo124/framework/src/Illuminate/Pipeline/Pipeline.php(149): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle(Object(Illuminate\Http\Request), Object(Closure))
#30 /var/www/invoiceninja/vendor/turbo124/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#31 /var/www/invoiceninja/vendor/turbo124/framework/src/Illuminate/Foundation/Http/Middleware/VerifyCsrfToken.php(68): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request))
#32 /var/www/invoiceninja/app/Http/Middleware/VerifyCsrfToken.php(44): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure))
#33 /var/www/invoiceninja/vendor/turbo124/framework/src/Illuminate/Pipeline/Pipeline.php(149): App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure))
#34 /var/www/invoiceninja/vendor/turbo124/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#35 /var/www/invoiceninja/vendor/turbo124/framework/src/Illuminate/View/Middleware/ShareErrorsFromSession.php(49): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request))
#36 /var/www/invoiceninja/vendor/turbo124/framework/src/Illuminate/Pipeline/Pipeline.php(149): Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure))
#37 /var/www/invoiceninja/vendor/turbo124/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#38 /var/www/invoiceninja/vendor/turbo124/framework/src/Illuminate/Session/Middleware/StartSession.php(63): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request))
#39 /var/www/invoiceninja/vendor/turbo124/framework/src/Illuminate/Pipeline/Pipeline.php(149): Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure))
#40 /var/www/invoiceninja/vendor/turbo124/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#41 /var/www/invoiceninja/vendor/turbo124/framework/src/Illuminate/Cookie/Middleware/AddQueuedCookiesToResponse.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request))
#42 /var/www/invoiceninja/vendor/turbo124/framework/src/Illuminate/Pipeline/Pipeline.php(149): Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure))
#43 /var/www/invoiceninja/vendor/turbo124/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#44 /var/www/invoiceninja/vendor/turbo124/framework/src/Illuminate/Cookie/Middleware/EncryptCookies.php(68): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request))
#45 /var/www/invoiceninja/vendor/turbo124/framework/src/Illuminate/Pipeline/Pipeline.php(149): Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure))
#46 /var/www/invoiceninja/vendor/turbo124/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#47 /var/www/invoiceninja/vendor/turbo124/framework/src/Illuminate/Pipeline/Pipeline.php(102): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request))
#48 /var/www/invoiceninja/vendor/turbo124/framework/src/Illuminate/Routing/Router.php(660): Illuminate\Pipeline\Pipeline->then(Object(Closure))
#49 /var/www/invoiceninja/vendor/turbo124/framework/src/Illuminate/Routing/Router.php(635): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request))
#50 /var/www/invoiceninja/vendor/turbo124/framework/src/Illuminate/Routing/Router.php(601): Illuminate\Routing\Router->runRoute(Object(Illuminate\Http\Request), Object(Illuminate\Routing\Route))
#51 /var/www/invoiceninja/vendor/turbo124/framework/src/Illuminate/Routing/Router.php(590): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request))
#52 /var/www/invoiceninja/vendor/turbo124/framework/src/Illuminate/Foundation/Http/Kernel.php(176): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request))
#53 /var/www/invoiceninja/vendor/turbo124/framework/src/Illuminate/Routing/Pipeline.php(30): Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request))
#54 /var/www/invoiceninja/vendor/turbo124/framework/src/Illuminate/Foundation/Http/Middleware/CheckForMaintenanceMode.php(46): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request))
#55 /var/www/invoiceninja/vendor/turbo124/framework/src/Illuminate/Pipeline/Pipeline.php(149): Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure))
#56 /var/www/invoiceninja/vendor/turbo124/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#57 /var/www/invoiceninja/vendor/barryvdh/laravel-cors/src/HandlePreflight.php(46): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request))
#58 /var/www/invoiceninja/vendor/turbo124/framework/src/Illuminate/Pipeline/Pipeline.php(149): Barryvdh\Cors\HandlePreflight->handle(Object(Illuminate\Http\Request), Object(Closure))
#59 /var/www/invoiceninja/vendor/turbo124/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#60 /var/www/invoiceninja/vendor/turbo124/framework/src/Illuminate/Pipeline/Pipeline.php(102): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request))
#61 /var/www/invoiceninja/vendor/turbo124/framework/src/Illuminate/Foundation/Http/Kernel.php(151): Illuminate\Pipeline\Pipeline->then(Object(Closure))
#62 /var/www/invoiceninja/vendor/turbo124/framework/src/Illuminate/Foundation/Http/Kernel.php(116): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request))
#63 /var/www/invoiceninja/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request))
