I recently upgraded to 2.5.1.2 from 2.4.9 - I think I was on 2.4.9.2… Had the .env issue with a space in one of the values and got that fixed. Now I’m trying to switch over from Authorize to Stripe for payments. I archived Authorize and added Stripe under 2.4.9. I did a “test” invoice to myself using Stripe in live mode. My payment would not go through and there was no indication why. I was on the payment page, entered my information, and clicked Pay, and the page refreshed and sent me back to the top without an errors. So I started the upgrade process from 2.4.9 to 2.5.1.2. Fixed the .env issue. Now when I go back to Online Payments to select edit my Stripe payment method, I get to https://invoice.lionlike.com/gateways/create and receive: Whoops, looks like something went wrong. Here is my laravel.log:
[2016-04-05 17:41:03] production.ERROR: exception ‘Omnipay\Common\Exception\RuntimeException’ with message ‘Class ‘\Omnipay\Neteller\Gateway’ not found’ in /var/www/ninja/vendor/omnipay/common/src/Omnipay/Common/GatewayFactory.php:105 Stack trace: #0 [internal function]: Omnipay\Common\GatewayFactory->create(‘Neteller’) #1 /var/www/ninja/vendor/omnipay/common/src/Omnipay/Omnipay.php(103): call_user_func_array(Array, Array) #2 /var/www/ninja/app/Models/Gateway.php(90): Omnipay\Omnipay::__callStatic(‘create’, Array) #3 /var/www/ninja/app/Models/Gateway.php(90): Omnipay\Omnipay::create(‘Neteller’) #4 /var/www/ninja/app/Http/Controllers/AccountGatewayController.php(133): App\Models\Gateway->getFields() #5 /var/www/ninja/app/Http/Controllers/AccountGatewayController.php(80): App\Http\Controllers\AccountGatewayController->getViewModel() #6 [internal function]: App\Http\Controllers\AccountGatewayController->create() #7 /var/www/ninja/bootstrap/cache/compiled.php(9363): call_user_func_array(Array, Array) #8 /var/www/ninja/bootstrap/cache/compiled.php(9425): Illuminate\Routing\Controller->callAction(‘create’, Array) #9 /var/www/ninja/bootstrap/cache/compiled.php(9405): Illuminate\Routing\ControllerDispatcher->call(Object(App\Http\Controllers\AccountGatewayController), Object(Illuminate\Routing\Route), ‘create’) #10 [internal function]: Illuminate\Routing\ControllerDispatcher->Illuminate\Routing{closure}(Object(Illuminate\Http\Request)) #11 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #12 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing{closure}(Object(Illuminate\Http\Request)) #13 /var/www/ninja/bootstrap/cache/compiled.php(9882): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #14 /var/www/ninja/bootstrap/cache/compiled.php(9406): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #15 /var/www/ninja/bootstrap/cache/compiled.php(9393): Illuminate\Routing\ControllerDispatcher->callWithinStack(Object(App\Http\Controllers\AccountGatewayController), Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), ‘create’) #16 /var/www/ninja/bootstrap/cache/compiled.php(8474): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request), ‘App\Http\Contro…’, ‘create’) #17 /var/www/ninja/bootstrap/cache/compiled.php(8461): Illuminate\Routing\Route->runController(Object(Illuminate\Http\Request)) #18 /var/www/ninja/bootstrap/cache/compiled.php(8175): Illuminate\Routing\Route->run(Object(Illuminate\Http\Request)) #19 [internal function]: Illuminate\Routing\Router->Illuminate\Routing{closure}(Object(Illuminate\Http\Request)) #20 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #21 /var/www/ninja/app/Http/Middleware/PermissionsRequired.php(44): Illuminate\Routing\Pipeline->Illuminate\Routing{closure}(Object(Illuminate\Http\Request)) #22 [internal function]: App\Http\Middleware\PermissionsRequired->handle(Object(Illuminate\Http\Request), Object(Closure)) #23 /var/www/ninja/bootstrap/cache/compiled.php(9892): call_user_func_array(Array, Array) #24 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline{closure}(Object(Illuminate\Http\Request)) #25 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #26 /var/www/ninja/app/Http/Middleware/Authenticate.php(69): Illuminate\Routing\Pipeline->Illuminate\Routing{closure}(Object(Illuminate\Http\Request)) #27 [internal function]: App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure), ‘user’) #28 /var/www/ninja/bootstrap/cache/compiled.php(9892): call_user_func_array(Array, Array) #29 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline{closure}(Object(Illuminate\Http\Request)) #30 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #31 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing{closure}(Object(Illuminate\Http\Request)) #32 /var/www/ninja/bootstrap/cache/compiled.php(9882): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #33 /var/www/ninja/bootstrap/cache/compiled.php(8176): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #34 /var/www/ninja/bootstrap/cache/compiled.php(8167): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request)) #35 /var/www/ninja/bootstrap/cache/compiled.php(8157): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request)) #36 /var/www/ninja/bootstrap/cache/compiled.php(2400): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request)) #37 [internal function]: Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http{closure}(Object(Illuminate\Http\Request)) #38 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(52): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #39 /var/www/ninja/app/Http/Middleware/StartupCheck.php(186): Illuminate\Routing\Pipeline->Illuminate\Routing{closure}(Object(Illuminate\Http\Request)) #40 [internal function]: app\Http\Middleware\StartupCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #41 /var/www/ninja/bootstrap/cache/compiled.php(9892): call_user_func_array(Array, Array) #42 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline{closure}(Object(Illuminate\Http\Request)) #43 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #44 /var/www/ninja/app/Http/Middleware/DuplicateSubmissionCheck.php(33): Illuminate\Routing\Pipeline->Illuminate\Routing{closure}(Object(Illuminate\Http\Request)) #45 [internal function]: app\Http\Middleware\DuplicateSubmissionCheck->handle(Object(Illuminate\Http\Request), Object(Closure)) #46 /var/www/ninja/bootstrap/cache/compiled.php(9892): call_user_func_array(Array, Array) #47 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline{closure}(Object(Illuminate\Http\Request)) #48 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #49 /var/www/ninja/bootstrap/cache/compiled.php(3176): Illuminate\Routing\Pipeline->Illuminate\Routing{closure}(Object(Illuminate\Http\Request)) #50 /var/www/ninja/app/Http/Middleware/VerifyCsrfToken.php(42): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #51 [internal function]: App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure)) #52 /var/www/ninja/bootstrap/cache/compiled.php(9892): call_user_func_array(Array, Array) #53 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline{closure}(Object(Illuminate\Http\Request)) #54 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #55 /var/www/ninja/bootstrap/cache/compiled.php(13328): Illuminate\Routing\Pipeline->Illuminate\Routing{closure}(Object(Illuminate\Http\Request)) #56 [internal function]: Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #57 /var/www/ninja/bootstrap/cache/compiled.php(9892): call_user_func_array(Array, Array) #58 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline{closure}(Object(Illuminate\Http\Request)) #59 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #60 /var/www/ninja/bootstrap/cache/compiled.php(11876): Illuminate\Routing\Pipeline->Illuminate\Routing{closure}(Object(Illuminate\Http\Request)) #61 [internal function]: Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure)) #62 /var/www/ninja/bootstrap/cache/compiled.php(9892): call_user_func_array(Array, Array) #63 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline{closure}(Object(Illuminate\Http\Request)) #64 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #65 /var/www/ninja/bootstrap/cache/compiled.php(13063): Illuminate\Routing\Pipeline->Illuminate\Routing{closure}(Object(Illuminate\Http\Request)) #66 [internal function]: Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure)) #67 /var/www/ninja/bootstrap/cache/compiled.php(9892): call_user_func_array(Array, Array) #68 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline{closure}(Object(Illuminate\Http\Request)) #69 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #70 /var/www/ninja/bootstrap/cache/compiled.php(13000): Illuminate\Routing\Pipeline->Illuminate\Routing{closure}(Object(Illuminate\Http\Request)) #71 [internal function]: Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure)) #72 /var/www/ninja/bootstrap/cache/compiled.php(9892): call_user_func_array(Array, Array) #73 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline{closure}(Object(Illuminate\Http\Request)) #74 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #75 /var/www/ninja/bootstrap/cache/compiled.php(3237): Illuminate\Routing\Pipeline->Illuminate\Routing{closure}(Object(Illuminate\Http\Request)) #76 [internal function]: Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure)) #77 /var/www/ninja/bootstrap/cache/compiled.php(9892): call_user_func_array(Array, Array) #78 [internal function]: Illuminate\Pipeline\Pipeline->Illuminate\Pipeline{closure}(Object(Illuminate\Http\Request)) #79 /var/www/ninja/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(32): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #80 [internal function]: Illuminate\Routing\Pipeline->Illuminate\Routing{closure}(Object(Illuminate\Http\Request)) #81 /var/www/ninja/bootstrap/cache/compiled.php(9882): call_user_func(Object(Closure), Object(Illuminate\Http\Request)) #82 /var/www/ninja/bootstrap/cache/compiled.php(2347): Illuminate\Pipeline\Pipeline->then(Object(Closure)) #83 /var/www/ninja/bootstrap/cache/compiled.php(2331): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request)) #84 /var/www/ninja/public/index.php(53): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #85 {main} [] []
I’ve tried updating composer already as well.
Any help would be greatly appreciated.
