Hello - I have successfully installed IN 5.3.16 on shared hosting using Softaculous. System wide PHP version on this host is 7.2 but I changed PHP to 7.4 for IN install. Everything appear to be working. So far so good.
After a while I saw ‘update available’ in blue triangle. When I clicked ‘update’, it ended up in this error:
Composer detected issues in your platform: Your Composer dependencies require a PHP version “>= 7.4.0”.
I can’t seems to be find a solution to this problem. Any suggestion?
On a different note: What should be the disk space requirement for about 100 customers with no documents (only invoices)? The current host I am using has 10GB.
