I’ve moved hosts and had to upgrade from 5.5.5 to the latest 5.5.68.
- Installed all files fresh on the server, from the latest .zip release
- Made sure to 755 alle files
- Copied the .env file from the 5.5.5 version and adjusted the DB, mail, etc. settings
- Ran php artisan optimize
- Visited mydomain.com/update?secret=_______
- Got 500 error (detailed below)
I get a perfect login screen, but can’t login (500 error, stating missing table, bank_integrations)
ValueError:
DOMDocument::loadHTML(): Argument #1 ($source) must not be empty
at /home/mydomain.com/app/Services/PdfMaker/Designs/Utilities/DesignHelpers.php:96
at DOMDocument->loadHTML('')
(/home/mydomain.com/app/Services/PdfMaker/Designs/Utilities/DesignHelpers.php:96)
at App\Services\PdfMaker\Design->document()
(/home/mydomain.com/app/Console/Commands/DesignUpdate.php:75)
at App\Console\Commands\DesignUpdate->handleOnDb()
(/home/mydomain.com/app/Console/Commands/DesignUpdate.php:57)
at App\Console\Commands\DesignUpdate->handle()
(/home/mydomain.com/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php:36)
at Illuminate\Container\BoundMethod::Illuminate\Container\{closure}()
(/home/mydomain.com/vendor/laravel/framework/src/Illuminate/Container/Util.php:41)
at Illuminate\Container\Util::unwrapIfClosure(object(Closure))
(/home/mydomain.com/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php:93)
at Illuminate\Container\BoundMethod::callBoundMethod(object(Application), array(object(DesignUpdate), 'handle'), object(Closure))
(/home/mydomain.com/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php:35)
at Illuminate\Container\BoundMethod::call(object(Application), array(object(DesignUpdate), 'handle'), array(), null)
(/home/mydomain.com/vendor/laravel/framework/src/Illuminate/Container/Container.php:663)
at Illuminate\Container\Container->call(array(object(DesignUpdate), 'handle'))
(/home/mydomain.com/vendor/laravel/framework/src/Illuminate/Console/Command.php:182)
at Illuminate\Console\Command->execute(object(StringInput), object(OutputStyle))
(/home/mydomain.com/vendor/symfony/console/Command/Command.php:312)
at Symfony\Component\Console\Command\Command->run(object(StringInput), object(OutputStyle))
(/home/mydomain.com/vendor/laravel/framework/src/Illuminate/Console/Command.php:151)
at Illuminate\Console\Command->run(object(StringInput), object(BufferedOutput))
(/home/mydomain.com/vendor/symfony/console/Application.php:1022)
at Symfony\Component\Console\Application->doRunCommand(object(DesignUpdate), object(StringInput), object(BufferedOutput))
(/home/mydomain.com/vendor/symfony/console/Application.php:314)
at Symfony\Component\Console\Application->doRun(object(StringInput), object(BufferedOutput))
(/home/mydomain.com/vendor/symfony/console/Application.php:168)
at Symfony\Component\Console\Application->run(object(StringInput), object(BufferedOutput))
(/home/mydomain.com/vendor/laravel/framework/src/Illuminate/Console/Application.php:102)
at Illuminate\Console\Application->run(object(StringInput), object(BufferedOutput))
(/home/mydomain.com/vendor/laravel/framework/src/Illuminate/Console/Application.php:193)
at Illuminate\Console\Application->call('ninja:design-update', array(), null)
(/home/mydomain.com/vendor/laravel/framework/src/Illuminate/Foundation/Console/Kernel.php:336)
at Illuminate\Foundation\Console\Kernel->call('ninja:design-update')
(/home/mydomain.com/vendor/laravel/framework/src/Illuminate/Support/Facades/Facade.php:338)
at Illuminate\Support\Facades\Facade::__callStatic('call', array('ninja:design-update'))
(/home/mydomain.com/database/migrations/2022_06_10_030503_set_account_flag_for_react.php:23)
at Illuminate\Database\Migrations\Migration@anonymous/home/mydomain.com/database/migrations/2022_06_10_030503_set_account_flag_for_react.php:15$1d7->up()
(/home/mydomain.com/vendor/laravel/framework/src/Illuminate/Database/Migrations/Migrator.php:481)
at Illuminate\Database\Migrations\Migrator->runMethod(object(MySqlConnection), object(Migration@anonymous), 'up')
(/home/mydomain.com/vendor/laravel/framework/src/Illuminate/Database/Migrations/Migrator.php:399)
at Illuminate\Database\Migrations\Migrator->Illuminate\Database\Migrations\{closure}()
(/home/mydomain.com/vendor/laravel/framework/src/Illuminate/Database/Migrations/Migrator.php:408)
at Illuminate\Database\Migrations\Migrator->runMigration(object(Migration@anonymous), 'up')
(/home/mydomain.com/vendor/laravel/framework/src/Illuminate/Database/Migrations/Migrator.php:209)
(/home/mydomain.com/vendor/laravel/framework/src/Illuminate/Console/View/Components/Task.php:36)
at Illuminate\Console\View\Components\Task->render('2022_06_10_030503_set_account_flag_for_react', object(Closure))
(/home/mydomain.com/vendor/laravel/framework/src/Illuminate/Database/Migrations/Migrator.php:738)
at Illuminate\Database\Migrations\Migrator->write('Illuminate\\Console\\View\\Components\\Task', '2022_06_10_030503_set_account_flag_for_react', object(Closure))
at Illuminate\Database\Migrations\Migrator->runUp('/home/mydomain.com/database/migrations/2022_06_10_030503_set_account_flag_for_react.php', 6, false)
(/home/mydomain.com/vendor/laravel/framework/src/Illuminate/Database/Migrations/Migrator.php:174)
at Illuminate\Database\Migrations\Migrator->runPending(array('/home/mydomain.com/database/migrations/2022_06_10_030503_set_account_flag_for_react.php', '/home/mydomain.com/database/migrations/2022_06_16_025156_add_react_switching_flag.php', '/home/mydomain.com/database/migrations/2022_06_17_082627_change_refresh_token_column_size.php', '/home/mydomain.com/database/migrations/2022_06_21_104350_fixes_for_description_in_pdf_designs.php', '/home/mydomain.com/database/migrations/2022_06_22_090547_set_oauth_expiry_column.php', '/home/mydomain.com/database/migrations/2022_06_24_141018_upgrade_failed_jobs_table.php', '/home/mydomain.com/database/migrations/2022_06_30_000126_add_flag_to_accounts_table.php', '/home/mydomain.com/database/migrations/2022_07_06_080127_add_purchase_order_to_expense.php', '/home/mydomain.com/database/migrations/2022_07_09_235510_add_index_to_payment_hash.php', '/home/mydomain.com/database/migrations/2022_07_12_45766_add_matomo.php', '/home/mydomain.com/database/migrations/2022_07_18_033756_fixes_for_date_formats_table_react.php', '/home/mydomain.com/database/migrations/2022_07_21_023805_add_hebrew_language.php', '/home/mydomain.com/database/migrations/2022_07_26_091216_add_sms_verification_to_hosted_account.php', '/home/mydomain.com/database/migrations/2022_07_28_232340_enabled_expense_tax_rates_to_companies_table.php', '/home/mydomain.com/database/migrations/2022_07_29_091235_correction_for_companies_table_types.php', '/home/mydomain.com/database/migrations/2022_08_05_023357_bank_integration.php', '/home/mydomain.com/database/migrations/2022_08_11_011534_licenses_table_for_self_host.php', '/home/mydomain.com/database/migrations/2022_08_24_215917_invoice_task_project_companies_table.php', '/home/mydomain.com/database/migrations/2022_08_26_232500_add_email_status_column_to_purchase_order_invitations_table.php', '/home/mydomain.com/database/migrations/2022_08_28_210111_add_index_to_payments_table.php', '/home/mydomain.com/database/migrations/2022_09_05_024719_update_designs_for_tech_template.php', '/home/mydomain.com/database/migrations/2022_09_07_101731_add_reporting_option_to_companies_table.php', '/home/mydomain.com/database/migrations/2022_09_21_012417_add_threeds_to_braintree.php', '/home/mydomain.com/database/migrations/2022_09_30_235337_add_idempotency_key_to_payments.php', '/home/mydomain.com/database/migrations/2022_10_05_205645_add_indexes_to_client_hash.php', '/home/mydomain.com/database/migrations/2022_10_06_011344_add_key_to_products.php', '/home/mydomain.com/database/migrations/2022_10_07_065455_add_key_to_company_tokens_table.php', '/home/mydomain.com/database/migrations/2022_10_10_070137_add_documentable_index.php', '/home/mydomain.com/database/migrations/2022_10_27_044909_add_user_sms_verification_code.php', '/home/mydomain.com/database/migrations/2022_11_02_063742_add_verified_number_flag_to_users_table.php', '/home/mydomain.com/database/migrations/2022_11_04_013539_disabled_upstream_bank_integrations_table.php', '/home/mydomain.com/database/migrations/2022_11_06_215526_drop_html_backups_column_from_backups_table.php', '/home/mydomain.com/database/migrations/2022_11_13_034143_bank_transaction_rules_table.php', '/home/mydomain.com/database/migrations/2022_11_16_093535_calmness_design.php', '/home/mydomain.com/database/migrations/2022_11_22_215618_lock_tasks_when_invoiced.php', '/home/mydomain.com/database/migrations/2022_11_30_063229_add_payment_id_to_bank_transaction_table.php', '/home/mydomain.com/database/migrations/2022_12_07_024625_add_properties_to_companies_table.php', '/home/mydomain.com/database/migrations/2022_12_14_004639_vendor_currency_update.php', '/home/mydomain.com/database/migrations/2022_12_20_063038_set_proforma_invoice_type.php', '/home/mydomain.com/database/migrations/2023_01_12_125540_set_auto_bill_on_regular_invoice_setting.php', '/home/mydomain.com/database/migrations/2023_01_27_023127_update_design_templates.php', '/home/mydomain.com/database/migrations/2023_02_02_062938_add_additional_required_fields_gateways.php', '/home/mydomain.com/database/migrations/2023_02_05_042351_add_foreign_key_for_vendors.php'), array('pretend' => false, 'step' => false))
(/home/mydomain.com/vendor/laravel/framework/src/Illuminate/Database/Migrations/Migrator.php:117)
at Illuminate\Database\Migrations\Migrator->run(array('/home/mydomain.com/database/migrations'), array('pretend' => false, 'step' => false))
(/home/mydomain.com/vendor/laravel/framework/src/Illuminate/Database/Console/Migrations/MigrateCommand.php:88)
at Illuminate\Database\Console\Migrations\MigrateCommand->Illuminate\Database\Console\Migrations\{closure}()
(/home/mydomain.com/vendor/laravel/framework/src/Illuminate/Database/Migrations/Migrator.php:615)
at Illuminate\Database\Migrations\Migrator->usingConnection(null, object(Closure))
(/home/mydomain.com/vendor/laravel/framework/src/Illuminate/Database/Console/Migrations/MigrateCommand.php:81)
at Illuminate\Database\Console\Migrations\MigrateCommand->handle()
at Illuminate\Container\BoundMethod::callBoundMethod(object(Application), array(object(MigrateCommand), 'handle'), object(Closure))
at Illuminate\Container\BoundMethod::call(object(Application), array(object(MigrateCommand), 'handle'), array(), null)
at Illuminate\Container\Container->call(array(object(MigrateCommand), 'handle'))
at Illuminate\Console\Command->execute(object(ArrayInput), object(OutputStyle))
at Symfony\Component\Console\Command\Command->run(object(ArrayInput), object(OutputStyle))
at Illuminate\Console\Command->run(object(ArrayInput), object(BufferedOutput))
at Symfony\Component\Console\Application->doRunCommand(object(MigrateCommand), object(ArrayInput), object(BufferedOutput))
at Symfony\Component\Console\Application->doRun(object(ArrayInput), object(BufferedOutput))
at Symfony\Component\Console\Application->run(object(ArrayInput), object(BufferedOutput))
at Illuminate\Console\Application->run(object(ArrayInput), object(BufferedOutput))
at Illuminate\Console\Application->call('migrate', array('--force' => true), null)
at Illuminate\Foundation\Console\Kernel->call('migrate', array('--force' => true))
at Illuminate\Support\Facades\Facade::__callStatic('call', array('migrate', array('--force' => true)))
(/home/mydomain.com/app/Http/Controllers/SetupController.php:314)
at App\Http\Controllers\SetupController->update()
(/home/mydomain.com/vendor/laravel/framework/src/Illuminate/Routing/Controller.php:54)
at Illuminate\Routing\Controller->callAction('update', array())
(/home/mydomain.com/vendor/laravel/framework/src/Illuminate/Routing/ControllerDispatcher.php:43)
at Illuminate\Routing\ControllerDispatcher->dispatch(object(Route), object(SetupController), 'update')
(/home/mydomain.com/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Tracing/Routing/TracingControllerDispatcherTracing.php:21)
at Sentry\Laravel\Tracing\Routing\TracingControllerDispatcherTracing->Sentry\Laravel\Tracing\Routing\{closure}()
(/home/mydomain.com/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Tracing/Routing/TracingRoutingDispatcher.php:19)
at Sentry\Laravel\Tracing\Routing\TracingRoutingDispatcher->wrapRouteDispatch(object(Closure), object(Route))
(/home/mydomain.com/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Tracing/Routing/TracingControllerDispatcherTracing.php:20)
at Sentry\Laravel\Tracing\Routing\TracingControllerDispatcherTracing->dispatch(object(Route), object(SetupController), 'update')
(/home/mydomain.com/vendor/laravel/framework/src/Illuminate/Routing/Route.php:259)
at Illuminate\Routing\Route->runController()
(/home/mydomain.com/vendor/laravel/framework/src/Illuminate/Routing/Route.php:205)
at Illuminate\Routing\Route->run()
(/home/mydomain.com/vendor/laravel/framework/src/Illuminate/Routing/Router.php:798)
at Illuminate\Routing\Router->Illuminate\Routing\{closure}(object(Request))
(/home/mydomain.com/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php:141)
at Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(object(Request))
(/home/mydomain.com/app/Http/Middleware/RedirectIfAuthenticated.php:56)
at App\Http\Middleware\RedirectIfAuthenticated->handle(object(Request), object(Closure))
(/home/mydomain.com/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php:180)
(/home/mydomain.com/app/Http/Middleware/QueryLogging.php:39)
at App\Http\Middleware\QueryLogging->handle(object(Request), object(Closure))
(/home/mydomain.com/vendor/laravel/framework/src/Illuminate/Routing/Middleware/SubstituteBindings.php:50)
at Illuminate\Routing\Middleware\SubstituteBindings->handle(object(Request), object(Closure))
(/home/mydomain.com/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/VerifyCsrfToken.php:78)
at Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(object(Request), object(Closure))
(/home/mydomain.com/vendor/laravel/framework/src/Illuminate/View/Middleware/ShareErrorsFromSession.php:49)
at Illuminate\View\Middleware\ShareErrorsFromSession->handle(object(Request), object(Closure))
(/home/mydomain.com/vendor/laravel/framework/src/Illuminate/Cookie/Middleware/AddQueuedCookiesToResponse.php:37)
at Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(object(Request), object(Closure))
(/home/mydomain.com/app/Http/Middleware/SessionDomains.php:31)
at App\Http\Middleware\SessionDomains->handle(object(Request), object(Closure))
(/home/mydomain.com/vendor/laravel/framework/src/Illuminate/Session/Middleware/StartSession.php:121)
at Illuminate\Session\Middleware\StartSession->handleStatefulRequest(object(Request), object(Store), object(Closure))
(/home/mydomain.com/vendor/laravel/framework/src/Illuminate/Session/Middleware/StartSession.php:64)
at Illuminate\Session\Middleware\StartSession->handle(object(Request), object(Closure))
(/home/mydomain.com/vendor/laravel/framework/src/Illuminate/Cookie/Middleware/EncryptCookies.php:67)
at Illuminate\Cookie\Middleware\EncryptCookies->handle(object(Request), object(Closure))
(/home/mydomain.com/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php:116)
at Illuminate\Pipeline\Pipeline->then(object(Closure))
(/home/mydomain.com/vendor/laravel/framework/src/Illuminate/Routing/Router.php:797)
at Illuminate\Routing\Router->runRouteWithinStack(object(Route), object(Request))
(/home/mydomain.com/vendor/laravel/framework/src/Illuminate/Routing/Router.php:776)
at Illuminate\Routing\Router->runRoute(object(Request), object(Route))
(/home/mydomain.com/vendor/laravel/framework/src/Illuminate/Routing/Router.php:740)
at Illuminate\Routing\Router->dispatchToRoute(object(Request))
(/home/mydomain.com/vendor/laravel/framework/src/Illuminate/Routing/Router.php:729)
at Illuminate\Routing\Router->dispatch(object(Request))
(/home/mydomain.com/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php:190)
at Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(object(Request))
(/home/mydomain.com/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/SetRequestIpMiddleware.php:45)
at Sentry\Laravel\Http\SetRequestIpMiddleware->handle(object(Request), object(Closure))
(/home/mydomain.com/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/SetRequestMiddleware.php:30)
at Sentry\Laravel\Http\SetRequestMiddleware->handle(object(Request), object(Closure))
(/home/mydomain.com/vendor/livewire/livewire/src/DisableBrowserCache.php:19)
at Livewire\DisableBrowserCache->handle(object(Request), object(Closure))
(/home/mydomain.com/app/Http/Middleware/Cors.php:25)
at App\Http\Middleware\Cors->handle(object(Request), object(Closure))
(/home/mydomain.com/vendor/laravel/framework/src/Illuminate/Http/Middleware/TrustProxies.php:39)
at Illuminate\Http\Middleware\TrustProxies->handle(object(Request), object(Closure))
(/home/mydomain.com/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php:21)
at Illuminate\Foundation\Http\Middleware\TransformsRequest->handle(object(Request), object(Closure))
(/home/mydomain.com/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ConvertEmptyStringsToNull.php:31)
at Illuminate\Foundation\Http\Middleware\ConvertEmptyStringsToNull->handle(object(Request), object(Closure))
(/home/mydomain.com/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TrimStrings.php:40)
at Illuminate\Foundation\Http\Middleware\TrimStrings->handle(object(Request), object(Closure))
(/home/mydomain.com/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ValidatePostSize.php:27)
at Illuminate\Foundation\Http\Middleware\ValidatePostSize->handle(object(Request), object(Closure))
(/home/mydomain.com/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/PreventRequestsDuringMaintenance.php:86)
at Illuminate\Foundation\Http\Middleware\PreventRequestsDuringMaintenance->handle(object(Request), object(Closure))
(/home/mydomain.com/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Tracing/Middleware.php:52)
at Sentry\Laravel\Tracing\Middleware->handle(object(Request), object(Closure))
(/home/mydomain.com/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php:165)
at Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(object(Request))
(/home/mydomain.com/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php:134)
at Illuminate\Foundation\Http\Kernel->handle(object(Request))
(/home/mydomain.com/public/index.php:56)
