Website is down. App is down. Help Invoice Ninja.
https://invoicing.co/#/
AND
v5 app on windows computer
AND
Same here - I’m getting Cloudflare errors. #500 errors and various errors when it DOES let me login preventing me from updating.
Sorry for the trouble, the site should be back online now.
Please let us know if you see the error again.
The issue is persisting, I also keep getting this message whenever I try to make any change to an invoice, task or quote:
TimeoutException after 0:00:30.000000: Future not completed
the last time I got that error a couple times, and then the server went down completely. when it came back up I had duplicate quotes from my effort to create one. tried deleting one of the quotes, got the same error.
Thanks, we’re continuing to look into the issue.
If it helps, I’m receiving a 525 (SSL) error when I attempt to log in from the desktop app (Windows).
I’m Getting a TimeoutException after 0:00:30.000000: Future not completed whenever I try to save any amendment. this is using the IOS app on macbook.
Thank you for your patience, we’re actively working on it…
