501:
501 Not ImplementedNot Implemented
GET not supported for current URL.
Additionally, a 501 Not Implemented error was encountered while trying to use an ErrorDocument to handle the request.
501:
501 Not ImplementedGET not supported for current URL.
Also, was the app working previously?
Hi Hillel,
I’ve this on my domain and works fine however i recommended to my friend and bought domain and hosted this invoice ninja and it’s getting error for the first time, not able to save anything and getting the error
Does changing to the React app help?
That looks like the Flutter app, there’s a button at the top of the dashboard in the Flutter app which will enable you to change to the React app.
How have you installed the application?
If you have not used one from the releases section of github, you would see this issue.
