Hello
I have a error after latest update when i try to update any settings from my Company,
This is when i try to modify Footer from Invoice, do you know in what log to watch? Because in laravel.log is nothing
Hello
Web server Log:
2023/05/02 13:26:46 [error] 301645#301645: *104115 FastCGI sent in stderr: “PHP message: PHP Deprecated: Return type of League\Fractal\ParamBag::offsetExists($key) should either be compatible with ArrayAccess::offsetExists(mixed $offset): bool, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in /var/www/html/invoiceninja_v5/vendor/league/fractal/src/ParamBag.php on line 108” while reading response header from upstream, client: 172.71.182.141, server: orasys-it-solutions.net, request: “PUT /api/v1/companies/VolejRejNm? HTTP/2.0”, upstream: “fastcgi://unix:/run/php/php8.1-fpm.sock:”, host: “orasys-it-solutions.net”, referrer: “https://orasys-it-solutions.net/”
And i saw now when i send Invoice, don’t want to send mail to client with invoice
Another log from laravel.log when i try force upgrade:
[2023-05-02 10:47:55] production.ERROR: Undefined property: stdClass::$enable_e_invoice {“exception”:"[object] (ErrorException(code: 0): Undefined property: stdClass::$enable_e_invoice at /var/www/html/invoiceninja_v5/app/Services/Email/EmailDefaults.php:302)
#0 /var/www/html/invoiceninja_v5/vendor/laravel/framework/src/Illuminate/Foundation/Bootstrap/HandleExceptions.php(266): Illuminate\Foundation\Bootstrap\HandleExceptions->handleError()
#1 /var/www/html/invoiceninja_v5/app/Services/Email/EmailDefaults.php(302): Illuminate\Foundation\Bootstrap\HandleExceptions->Illuminate\Foundation\Bootstrap\{closure}()
#2 /var/www/html/invoiceninja_v5/app/Services/Email/EmailDefaults.php(81): App\Services\Email\EmailDefaults->setAttachments()
#3 /var/www/html/invoiceninja_v5/app/Services/Email/Email.php(205): App\Services\Email\EmailDefaults->run()
#4 /var/www/html/invoiceninja_v5/app/Services/Email/Email.php(87): App\Services\Email\Email->setDefaults()
#5 /var/www/html/invoiceninja_v5/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(36): App\Services\Email\Email->handle()
#6 /var/www/html/invoiceninja_v5/vendor/laravel/framework/src/Illuminate/Container/Util.php(41): Illuminate\Container\BoundMethod::Illuminate\Container\{closure}()
#7 /var/www/html/invoiceninja_v5/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(93): Illuminate\Container\Util::unwrapIfClosure()
#8 /var/www/html/invoiceninja_v5/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(37): Illuminate\Container\BoundMethod::callBoundMethod()
#9 /var/www/html/invoiceninja_v5/vendor/laravel/framework/src/Illuminate/Container/Container.php(661): Illuminate\Container\BoundMethod::call()
#10 /var/www/html/invoiceninja_v5/vendor/laravel/framework/src/Illuminate/Bus/Dispatcher.php(128): Illuminate\Container\Container->call()
#11 /var/www/html/invoiceninja_v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(141): Illuminate\Bus\Dispatcher->Illuminate\Bus\{closure}()
#12 /var/www/html/invoiceninja_v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(116): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#13 /var/www/html/invoiceninja_v5/vendor/laravel/framework/src/Illuminate/Bus/Dispatcher.php(132): Illuminate\Pipeline\Pipeline->then()
#14 /var/www/html/invoiceninja_v5/vendor/laravel/framework/src/Illuminate/Queue/CallQueuedHandler.php(124): Illuminate\Bus\Dispatcher->dispatchNow()
#15 /var/www/html/invoiceninja_v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(141): Illuminate\Queue\CallQueuedHandler->Illuminate\Queue\{closure}()
#16 /var/www/html/invoiceninja_v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(116): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#17 /var/www/html/invoiceninja_v5/vendor/laravel/framework/src/Illuminate/Queue/CallQueuedHandler.php(126): Illuminate\Pipeline\Pipeline->then()
#18 /var/www/html/invoiceninja_v5/vendor/laravel/framework/src/Illuminate/Queue/CallQueuedHandler.php(70): Illuminate\Queue\CallQueuedHandler->dispatchThroughMiddleware()
#19 /var/www/html/invoiceninja_v5/vendor/laravel/framework/src/Illuminate/Queue/Jobs/Job.php(98): Illuminate\Queue\CallQueuedHandler->call()
#20 /var/www/html/invoiceninja_v5/vendor/laravel/framework/src/Illuminate/Queue/Worker.php(425): Illuminate\Queue\Jobs\Job->fire()
#21 /var/www/html/invoiceninja_v5/vendor/laravel/framework/src/Illuminate/Queue/Worker.php(375): Illuminate\Queue\Worker->process()
#22 /var/www/html/invoiceninja_v5/vendor/laravel/framework/src/Illuminate/Queue/Worker.php(173): Illuminate\Queue\Worker->runJob()
#23 /var/www/html/invoiceninja_v5/vendor/laravel/framework/src/Illuminate/Queue/Console/WorkCommand.php(148): Illuminate\Queue\Worker->daemon()
#24 /var/www/html/invoiceninja_v5/vendor/laravel/framework/src/Illuminate/Queue/Console/WorkCommand.php(131): Illuminate\Queue\Console\WorkCommand->runWorker()
#25 /var/www/html/invoiceninja_v5/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(36): Illuminate\Queue\Console\WorkCommand->handle()
#26 /var/www/html/invoiceninja_v5/vendor/laravel/framework/src/Illuminate/Container/Util.php(41): Illuminate\Container\BoundMethod::Illuminate\Container\{closure}()
#27 /var/www/html/invoiceninja_v5/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(93): Illuminate\Container\Util::unwrapIfClosure()
#28 /var/www/html/invoiceninja_v5/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(37): Illuminate\Container\BoundMethod::callBoundMethod()
#29 /var/www/html/invoiceninja_v5/vendor/laravel/framework/src/Illuminate/Container/Container.php(661): Illuminate\Container\BoundMethod::call()
#30 /var/www/html/invoiceninja_v5/vendor/laravel/framework/src/Illuminate/Console/Command.php(183): Illuminate\Container\Container->call()
#31 /var/www/html/invoiceninja_v5/vendor/symfony/console/Command/Command.php(312): Illuminate\Console\Command->execute()
#32 /var/www/html/invoiceninja_v5/vendor/laravel/framework/src/Illuminate/Console/Command.php(153): Symfony\Component\Console\Command\Command->run()
#33 /var/www/html/invoiceninja_v5/vendor/symfony/console/Application.php(1022): Illuminate\Console\Command->run()
#34 /var/www/html/invoiceninja_v5/vendor/symfony/console/Application.php(314): Symfony\Component\Console\Application->doRunCommand()
#35 /var/www/html/invoiceninja_v5/vendor/symfony/console/Application.php(168): Symfony\Component\Console\Application->doRun()
#36 /var/www/html/invoiceninja_v5/vendor/laravel/framework/src/Illuminate/Console/Application.php(102): Symfony\Component\Console\Application->run()
#37 /var/www/html/invoiceninja_v5/vendor/laravel/framework/src/Illuminate/Foundation/Console/Kernel.php(155): Illuminate\Console\Application->run()
#38 /var/www/html/invoiceninja_v5/artisan(37): Illuminate\Foundation\Console\Kernel->handle()
#39 {main}
Something is very strange because on Iphone App everything work like a charm
Maybe my cache is broken?
Other users have been able to resolve this error by saving their settings.
@david do you have any ideas?
Yes , i have this problem only in web interface, but i think i will migrate to another server to see if error persist.
Only if you have a hint on what to do i ask
5.5.14 should have this issue resolved now.
is same error but this is only from browser i told you, in Linux App or iOS everything work good
For me its not working any where, on browser, on iPhone app, no where, I get the 500 server error and nothing has helped
after reinstall php and OS is the same problem
I have this error:
sudo -u www-data php8.1 artisan migrate
[sudo] password for adrian:
APPLICATION IN PRODUCTION.
Do you really wish to run this command? (yes/no) [no]
❯ yes
INFO Running migrations.
2023_01_31_191407_create_jobs_table … 3ms FAIL
In Connection.php line 760:
SQLSTATE[42S01]: Base table or view already exists: 1050 Table ‘jobs’ already exists (SQL: create table jobs
(id
bigint unsigned not null auto_increment primary key, queue
varchar(191) not nu
ll, payload
longtext not null, attempts
tinyint unsigned not null, reserved_at
int unsigned null, available_at
int unsigned not null, created_at
int unsigned not null) default character s
et utf8mb4 collate ‘utf8mb4_unicode_ci’ engine = InnoDB)
In Connection.php line 545:
Need to drop that table from database?
and this i am running on a PROD env where i have all my invoice, this will delete data from table?
This is strange as we dont have that particular date in the migrations table.
Can you move the file
database/migrations/2023_01_31_191407_create_jobs_table…
out of that directory temporarily and then reattempt the migrations.
Now everything run normal.
❯ yes
2023_02_02_062938_add_additional_required_fields_gateways … 49ms DONE
2023_02_05_042351_add_foreign_key_for_vendors … 0ms DONE
2023_02_07_114011_add_additional_product_fields … 36ms DONE
2023_02_14_064135_create_react_settings_column_company_user_table … 62ms DONE
2023_02_28_064453_update_designs … 8ms DONE
2023_02_28_200056_add_visible_prop_to_companies_table … 4ms DONE
2023_03_09_121033_add_payment_balance_to_clients_table … 23ms DONE
2023_03_10_100629_add_currencies … 2ms DONE
2023_03_13_156872_add_e_invoice_type_to_clients_table … 53ms DONE
2023_03_17_012309_add_proforma_flag_for_recurring_invoices … 26ms DONE
2023_03_21_053933_tax_calculations_for_invoices … 224ms DONE
2023_03_24_054758_add_client_is_exempt_from_taxes … 364ms DONE
2023_04_20_215159_drop_e_invoice_type_column … 32ms DONE
2023_04_27_045639_add_kmher_language … 50ms DONE
2023_05_03_023956_add_shopify_user_id … 143ms DONE
2023_05_15_103212_e_invoice_ssl_storage … 32ms DONE
And save button work again.
