Self Hosted on Amazon AWS Centos 7.9
php 7.4
Not able to modify invoice templates or even preview them in standard and in html mode as well.
php 7.4
I do see an error in the bottom left tray “Crons need to be enabled” and then when I do a system health check, it says that I need to enable “Queue”.I am also going to look in the “storage/logs” (Might take a minute to find)
FYI… the crons are required, the queue is optional
Ok I setup a cron in Cpanel to do daily with this script… cd /home/rocketmouse4422/public_html/acct1 && /opt/cpanel/ea-php74/root/usr/bin/php -d register_argc_argv=On artisan schedule:run >> /dev/null 2>&1 but I still have the redish triangle…
Try loading /update?secret=
Sorry Hillel, where would I run/load that?
You can load the URL in your browser, ie. https://site.com/update?secret=
