Hello I do not know what is happening but today after many tries to get access to my billing portal I got this error message, somebody can give some advice .
I forget to mention that I was installed Invoice Ninja via Softaculous . Long time ago
After reviewed the error log show me this errors: Fatal error : Uncaught Error: Class ‘Request’ not found in /home/basocons/public_html/billing/app/Exceptions/Handler.php:106 Stack trace: #0 /home/basocons/public_html/billing/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(326): App\Exceptions\Handler->render(Object(Illuminate\Http\Request), Object(InvalidArgumentException)) #1 /home/basocons/public_html/billing/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(120): Illuminate\Foundation\Http\Kernel->renderException(Object(Illuminate\Http\Request), Object(InvalidArgumentException)) #2 /home/basocons/public_html/billing/public/index.php(51): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request)) #3 {main} thrown in /home/basocons/public_html/billing/app/Exceptions/Handler.php on line 106
To be honest I do not know juts the server got and update and now is failing, with wihc version of PHP should be the best to this veriosn of the Software? maybe I will apply a new configuration.
Ok, after read the document you sent me before to move forward and upgrade from v4 to v5 I found this: I must to get access to my software and start the process to migrate to the next version, but how can I do that if I not able to get access to my main dashboard, I apologized but I do not understand.
