I update my invoice ninja from 5.3.44 to 5.3.48.
I got an 500 error.
In SSH i typed the command php artisan optimize: this was the output.
PHP Notice: Trying to access array offset on value of type null in /home/domains/public_html/vendor/laravel/framework/src/Illuminate/Support/Facades/Schema.php on line 45
PHP Fatal error: Uncaught Error: Call to a member function connection() on null in /home/domains/public_html/vendor/laravel/framework/src/Illuminate/Support/Facades/Schema.php:45
Stack trace:
#0 /home/domains/public_html/vendor/laravel/framework/src/Illuminate/Support/Facades/Facade.php(166): Illuminate\Support\Facades\Schema::getFacadeAccessor()
#1 /home/domains/public_html/vendor/laravel/framework/src/Illuminate/Support/Facades/Facade.php(255): Illuminate\Support\Facades\Facade::getFacadeRoot()
#2 /home/domains/public_html/app/Exceptions/Handler.php(78): Illuminate\Support\Facades\Facade::__callStatic(‘hasTable’, Array)
#3 /home/domains/public_html/vendor/laravel/framework/src/Illuminate/Foundation/Console/Kernel.php(366): App\Exceptions\Handler->report(Object(Error))
#4 /home/domains/public_ht in /home/domains/public_html/vendor/laravel/framework/src/Illuminate/Support/Facades/Schema.php on line 45
Any ideas ?
