Hi there, I just updated from v5.3.68 (just got it working properly after severe api problems)
to v5.3.73 through the UI. Now I get a 500 error on every page. With the following in dev tools console:
/public/:1 Failed to load resource: the server responded with a status of 500 () invoice.mydomain.nl/:1 GET https://invoice.mydomain.nl/ 500
flutter_service_worker.js?v=5.3.68:1 Uncaught (in promise) TypeError: Failed to execute ‘addAll’ on ‘Cache’: Request failed
I tried to clear the cache ?clear_cache=true without succes and also ran php artisan optimize within invoice.mydomain.nl. With the following response:
In Company.php line 29:
Trait “Awobaz\Compoships\Compoships” not found
This is the output of my /storage/logs/laravel.log (this is the last part, it has many of the same logs)
[2022-03-18 10:32:09] production.ERROR: Trait “Awobaz\Compoships\Compoships” not found {“exception”:"[object] (Symfony\Component\ErrorHandler\Error\FatalError(code: 0): Trait "Awobaz\Compoships\Compoships" not found at /home/myuser/invoice.mydomain.nl/app/Models/Company.php:29)
#0 /home/myuser/invoice.mydomain.nl/vendor/laravel/framework/src/Illuminate/Foundation/Bootstrap/HandleExceptions.php(217): Symfony\Component\ErrorHandler\Error\FatalError->__construct(message: '‘Trait "Awobaz\\…’, code: ‘0’, error: '[‘type’ => 1, ‘…’, traceOffset: ‘0’, traceArgs: ‘???’, trace: ‘???’)
#1 /home/myuser/invoice.mydomain.nl/vendor/laravel/framework/src/Illuminate/Foundation/Bootstrap/HandleExceptions.php(204): Illuminate\Foundation\Bootstrap\HandleExceptions->fatalErrorFromPhpError(error: ‘[‘type’ => 1, ‘…’, traceOffset: ‘0’)
#2 /home/myuser/invoice.mydomain.nl/vendor/laravel/framework/src/Illuminate/Foundation/Bootstrap/HandleExceptions.php(0): Illuminate\Foundation\Bootstrap\HandleExceptions->handleShutdown()
#3 /home/myuser/invoice.mydomain.nl/vendor/composer/ClassLoader.php(571): ()
#4 /home/myuser/invoice.mydomain.nl/vendor/composer/ClassLoader.php(428): Composer\Autoload\includeFile(file: ‘’/home/myuser…’)
#5 /home/myuser/invoice.mydomain.nl/app/Providers/EventServiceProvider.php(581): Composer\Autoload\ClassLoader->loadClass(class: '‘App\\\\Models\\\\C…’)
#6 /home/myuser/invoice.mydomain.nl/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(36): App\Providers\EventServiceProvider->boot()
#7 /home/myuser/invoice.mydomain.nl/vendor/laravel/framework/src/Illuminate/Container/Util.php(40): Illuminate\Container\BoundMethod::Illuminate\Container\{closure:/home/myuser/invoice.mydomain.nl/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php:35-37}()
#8 /home/myuser/invoice.mydomain.nl/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(93): Illuminate\Container\Util::unwrapIfClosure(value: ‘class Closure {…’)
#9 /home/myuser/invoice.mydomain.nl/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(37): Illuminate\Container\BoundMethod::callBoundMethod(container: ‘class Illuminat…’, callback: ‘[0 => class App…’, default: ‘class Closure {…’)
#10 /home/myuser/invoice.mydomain.nl/vendor/laravel/framework/src/Illuminate/Container/Container.php(653): Illuminate\Container\BoundMethod::call(container: ‘class Illuminat…’, callback: ‘[0 => class App…’, parameters: ‘’, defaultMethod: ‘NULL’)
#11 /home/myuser/invoice.mydomain.nl/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(924): Illuminate\Foundation\Application->call(callback: ‘[0 => class App…’, parameters: ‘???’, defaultMethod: ‘???’)
#12 /home/myuser/invoice.mydomain.nl/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(905): Illuminate\Foundation\Application->bootProvider(provider: ‘class App\\Provi…’)
#13 /home/myuser/invoice.mydomain.nl/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(906): Illuminate\Foundation\Application->Illuminate\Foundation\{closure:/home/myuser/invoice.mydomain.nl/vendor/laravel/framework/src/Illuminate/Foundation/Application.php:904-906}(p: ‘class App\\Provi…’, ‘35’)
#14 /home/myuser/invoice.mydomain.nl/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(906): array_walk(array: ‘[0 => class Ill…’, callback: ‘class Closure {…’)
#15 /home/myuser/invoice.mydomain.nl/vendor/laravel/framework/src/Illuminate/Foundation/Bootstrap/BootProviders.php(17): Illuminate\Foundation\Application->boot()
#16 /home/myuser/invoice.mydomain.nl/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(237): Illuminate\Foundation\Bootstrap\BootProviders->bootstrap(app: ‘class Illuminat…’)
#17 /home/myuser/invoice.mydomain.nl/vendor/laravel/framework/src/Illuminate/Foundation/Console/Kernel.php(310): Illuminate\Foundation\Application->bootstrapWith(bootstrappers: '[0 => ‘Illumina…’)
#18 /home/myuser/invoice.mydomain.nl/vendor/laravel/framework/src/Illuminate/Foundation/Console/Kernel.php(127): App\Console\Kernel->bootstrap()
#19 /home/myuser/invoice.mydomain.nl/artisan(37): App\Console\Kernel->handle(input: ‘class Symfony\\C…’, output: ‘class Symfony\\C…’)
#20 /home/myuser/invoice.mydomain.nl/artisan(0): {main}()
#21 {main}
