(carriage returns in above output were added by me, as the forum is not displaying CODE or BLOCKQUOTE correctly. It runs off the screen)
When I look up the invoices in the system, they are in a Draft status. That makes no sense to me. I can manually make them send out (“Email Invoice” button), and they go out.
However, the two invoices that were generated (last month) as still sitting there in Draft status, unsent. The error did not occur in the log after doing this manual send-invoices command.
Also, when I view the newly created Recurring invoice editor, it shows, “Sent Last: 13-Jul-2018”. So the system seems to think it’s sending them. But it’s generating an invoice, and leaving it in Draft, and not sending it.
I just noticed the owner permissions on the content of htdocs folder was all over the place. Many were correct, many were not. Including the .env files, had incorrect ownership.
I’ve set them all to what the server requries.
Is there anything I need to do to get the environment parameters read into where there are needed?
It’s a VM with Wordpress and Invoice Ninja running on it.
WP is running fine. Invoice Ninja is running mostly fine, except for the emails not going out.
If I was to ask the web host for help, what would I be asking them to do? I’ll need to do those things myself.
It seems odd to me that I can send test emails, and can manually send payment notices.
I notice, however, that when I manually send one of the recurring invoices (which is sitting there in Draft status), it appears to have sent, but then it remains in Draft status, and Mailgun does not show it was sent (so it’s not being sent).
Could all that be environment related? Seems more likely to be something with the app. Does it not?
