Emails marked as sent but not delivered to recipients (self-hosted, SMTP working)
Hi everyone,
I’m running a self-hosted version of Invoice Ninja (v5.11.61) and running into an issue where emails sent from the app (like invoices or reminders) are marked as sent, but never arrive in the recipient’s inbox, including Gmail and internal domains — not even in spam.
:white_check_mark: What I’ve confirmed so far:
  • SMTP is fully working
    • I’ve configured email settings via the admin panel
    • Test email (from the UI) sends successfully and is received by Gmail and other addresses
  • Using QUEUE_CONNECTION=sync to avoid background workers
  • Laravel logs (storage/logs/laravel.log) are empty — no errors
  • Tried a Laravel debug route (Mail::raw()) → mail successfully sends
  • SPF, DKIM, and DMARC are properly configured and pass in mail-tester.com (score: 7.6/10)
  • When I send email from the same address ([email protected]) using Thunderbird, the emails are delivered normally
  • But invoice emails from Invoice Ninja don’t arrive anywhere — not to Gmail, not even to my own domain ([email protected])
Key News Suriname
Self-hosted at: https://verkoop.thekeynetwork.sr
It may help with debugging to add your email as the BCC on Settings > Email Settings.
Hii, i already tried that.
I’m not sure, here’s what ChatGPT suggests:
Thanks for the detailed writeup — you’ve already covered a ton of ground, so kudos for narrowing it down this far. Since test emails and raw Laravel emails send fine, but actual Invoice Ninja emails don’t get delivered, it sounds like the problem may lie somewhere in how Invoice Ninja constructs or queues the messages, even if Laravel/Mail is working fine.
Here are some targeted ideas to investigate further:
:puzzle_piece: 1. Check Mail Headers / Content Differences
If you have access to the raw headers of test emails that work (from Mail::raw() or the test email in the UI), compare them to those generated by actual Invoice Ninja emails (you might be able to log or intercept them using something like Mailtrap or Mailhog).
You’re looking for differences like:
  • Missing From, Reply-To, or Message-ID
  • Suspicious HTML content or malformed headers
  • Bounce-inducing phrases in subject or body
:hammer_and_wrench: 2. Try Switching to Log Mail Driver
Temporarily set MAIL_MAILER=log in .env and trigger an invoice email. Then check storage/logs/laravel.log to inspect exactly what the email contains — this will help confirm if it’s being built as expected.
:magnifying_glass_tilted_left: 3. Look for Suppressed Messages
Some SMTP providers (like Amazon SES, Mailgun, or even your hosting provider) may silently drop certain messages if they think they’re spammy or repetitive — even if the SMTP transaction is successful.
If you’re using a mail provider:
  • Check their suppression list or dashboard
  • Check bounce/complaint feedback settings
  • Look for any throttling or reputation flags
:test_tube: 4. Try Changing the Email Content
Send a dummy invoice to yourself with a simplified subject and body, like “Test Invoice” and a basic line of text. This will help determine if the issue is content-related (eg. too many links, spammy phrases, large attachments, or problematic HTML).
:toolbox: 5. Use a Mail Interceptor Locally
Tools like:
These let you see exactly what Invoice Ninja is generating, which helps isolate whether it’s an email construction problem or something downstream.
:soap: 6. Double-check .env vs UI Email Settings
Sometimes .env settings (like MAIL_FROM_ADDRESS or MAIL_FROM_NAME) can override or conflict with the admin panel settings. Try clearing config cache just in case:
php artisan config:clear
php artisan cache:clear
php artisan optimize:clear
And restart PHP-FPM or your app container afterwards if needed.
:package: 7. Queue vs Sync – double-check behavior
Even though you’re using QUEUE_CONNECTION=sync, Invoice Ninja might still dispatch certain jobs that Laravel handles asynchronously. Try manually triggering an invoice email and watching logs in real-time (tail -f storage/logs/laravel.log) to catch anything subtle.
:mechanic: 8. Try Running a Failing Example via Tinker
You could simulate the same invoice email through php artisan tinker to see if anything pops:
use App\Models\Invoice;
use App\Jobs\Util\SendInvoiceEmail;
$invoice = Invoice::first();
SendInvoiceEmail::dispatchNow($invoice);
(or whatever the appropriate job/class is for your version)
If you want, I can help you test a few headers or even simulate the output of an invoice email to inspect for common spam triggers.
Let me know what mail provider or SMTP host you’re using too — that could help point to specific filters or suppression behaviors.
Thanks for the reply. I’m a journalist and know nothing about coding. I’ve already tried most of your suggestions with the help of ChatGPT, and went from no email sending at all to where I am now.
If you can fix this for me, I’d really appreciate it—and I’m more than willing to buy you a beer or two for your help! :slightly_smiling_face:
Sorry, if I knew the answer I’d tell you
Is the pdf generation working on your side?
I had this issue, when pdf was not working. Emails to the client with pdf attachments silently fail, if the pdf generation fails for the attachement. (The notification email without attachment to myself was send). As @hillel suggested BCC is good to debug, I use it now instead of notifications.
Maybe it is worth to disable attachments for a test.
yes pdf generation works fine.
Anybody willing to solve this for a fee ?
Something changed in how emails are sent I think; I had no issues in 5.4 but 5.11 is different. In 5.11 when the recipient is sent via SMTP it includes other stuff in the string like name and the < and > encapsulate the email. Not sure which email provider you’re using but mine was rejecting it. The issue is that Ninja was failing without anything the logs. I spent 10s of hours trying to track this down, i ended up having to put a python script to proxy the SMTP and strip out the recipient’s junk other than their email. The only way I figured this out was in my self hosted email server logs, if you’re not running your own email server I’m not sure if you could have seen this. I know that doesn’t directly help you but maybe someone can save themselves sometime.
Thanks for the feedback!
cc @david
Thanks but i am on QuickBooks now, this was getting way to complicated.
