I’ve changed the email theme which includes my logo by default I assume? But it’s constrained.
What options are there, if any, to fix this? Or do I have to use the custom code in email setings > raw - or remove the logo? Not ideal. https://d.pr/i/aqrfR5
Also, the plain and dark themes show “view now” button only and not the “pay now” button? How would I fix that? https://d.pr/i/ndQoSu
Are these options restricted in the app and not in the self hosted, ie. are there any difference between the two?
You’d need to use a logo with different dimensions.
You can add a pay now button to the email template, if you click the blue question mark to the right of the subject field you can see all the variables.
Hi, what is the recommended size / proportions for the logo on the email template?
I’ve noticed that my logo in emails is being squashed. This is happening after resizing the logo.
The problem is most likely related the aspect ratio of the image.
It’s possible (although somewhat tricky) to use a different image on the invoice by using a custom design, you can refer to the ‘Photo’ design for an example.
