Email setting not saved
Hi, i recently moved to a new server within the same host, the app was hosted on CentOS Linux 7 which reached end of life. The files now are on AlmaLinux 8 server and i have an issues with saving the email settings in the app. Each time i save the settings then try to send a test email i get this message:
“422: Unprocessable Content • The given data was invalid.
• The smtp username field is required.
• The smtp password field is required.”
If you’re using the web app it may help to try with the desktop app.
If it works in the desktop app but not the web app feel free to create an issue here:
I’m using both, and the issue is with both. i get the confirmation that the username and password are saved but they are actually not.
I’m not sure, you may want to ask in a discussion on GitHub.
