only install I moved the env to another folder still worked
just wondering if I should set it up on a a unraid server I have
You can try running php artisan config:clear
Google recently changed their policy on using the main account password in 3rd party apps (You can’t).
You can enable 2fa and then create an app password specifically for your install and use that instead of the main password.
I assume they are referring to “Fall” as in the US Fall, September. If so, you can still use that method.
That’s what the article says, but I had exactly the same problem a week or so ago.
A website that was previously sending through a workspace address stopped working.
