Email send stopped working
Hi.
As of recently email are not being sent out anymore. Didn’t touch a thing except did the Invoice Ninja updates.
Changing TSL, SSL, ports doesn’t seem to change anything. I can send out e-mail using telenet from ac ommand line.
So what is the very less stressful procedure to test email sending? How should I proceed to troubleshoot.
What I do now…
  • change and save.env file
  • php artisan optimize
  • clear cache
  • resend (email) the exisiting quote
-env settings that used to work before
MAIL_MAILER=smtp
MAIL_HOST=mail.mydomain.com
MAIL_PORT=25
MAIL_USERNAME=payments.mydomain.com
MAIL_PASSWORD=xxxxxxxxxxxxxxxxx
MAIL_ENCRYPTION=
[email protected]
MAIL_FROM_NAME=Payments
LOG
[2022-08-12 14:23:01] production.INFO: trying to send to [email protected] 2022-08-12 14:23:01
[2022-08-12 14:23:01] production.INFO: Using mailer => smtp
[2022-08-12 14:23:01] production.INFO: error failed with Failed to authenticate on SMTP server with username “payment
s.dbstudio.si” using the following authenticators: “LOGIN”, “PLAIN”. Authenticator “LOGIN” returned “Expected respons
e code “235” but got code “535”, with message “535 5.7.8 Error: authentication failed: authentication failure”.”. Aut
henticator “PLAIN” returned “Expected response code “235” but got code “535”, with message “535 5.7.8 Error: authenti
@david any thoughts?
Wait, it works for new quotes, but won’t resend out old ones. Strange, but it works.
Please ignore it.
Thank you for quick response Hillel.
Br,
Dali
ok but I have the same issue but want to be able to send old ones because my reminders are not send out.
production.INFO: error failed with Failed to authenticate on SMTP server with username “” using the following authenticators: “LOGIN”, “XOAUTH2”. Authenticator “LOGIN” returned “Expected response code “235” but got code “535”, with message “535 5.7.3 Authentication unsuccessful [AM0PR04CA0039.eurprd04.prod.outlook.com 2023-03-17T15:37:07.478Z 08DB2699D0179B67]”.”. Authenticator “XOAUTH2” returned “Expected response code “235” but got code “535”, with message “535 5.7.3 Authentication unsuccessful [AM0PR04CA0039.eurprd04.prod.outlook.com 2023-03-17T15:37:18.274Z 08DB2699D0179B67]”.”.
