I’ve recently just installed v5 after i borked my recent install of v4. I realised this was legacy and didn’t have much on it so just decided to switch to 5.
5 was a fresh install. However, since installing v5 i can’t seem to view the PDFs which are created. It seems to just hang and then i get TimeoutException after 0:00:30.000000: Future not completed. I can migrate to /var/www/invoice-ninja/public/storage/XXX/XXX/Invoices and there’s a single PDF in there which is completely blank.
I’ve tried a number of the PDF options and i’m still having this issue.
The fie itself is there and i’ve re-ran the permissions several times. So it looks like the PDF cannot be generated due to the logo? Ive tried removing my custom logo but it then cannot locate new_logo.png under /public/images.
Currently at a loss here. Hopefully someone can help me
I’ve just attempted the link myself and i’m able to access it. Note, i’m currently not connected to my VPN. I’ll attempt to connect to my VPN and try again and update you.
So i’m still investigating as to why my VM cannot communicate with itself (well it can just not by http or https). However, I want to understand as to why the VM needs to contact it’s HTTPS address when the content is already on the VM itself?
I believe it’s in fact a bug. PDFs are displaying perfectly fine via the desktop apps on MacOS and Windows. However, as soon as I attempt to display via a browser such as Chrome/Edge/Firefox we get into a continuous spin as seen below:
@david appreciate all your help on this one thank you so much.
Console indicates it was loading over HTTPS but was requesting HTTP so was therefore being blocked. Had a look at my .env file and the site was set at http:// instead of https:// updated that, and it’s working now.
