Is there a way to edit the footer in Client Statements? I’ve got some text showing that appeared when we were 1st trying to set up invoice footers. I’ve tried removing all the Company Default Footers but the text being displayed is not in any setting I can find.
What, if anything, might blow up if I export, manually edit the json file, purge the company and then reimport the edited json file?
I saw the new statement options and have been playing, but I’m still getting a very old footer that was supposed to be for invoices only and was removed long ago.
I’ve gone through every client and manually applied template settings to them all with no visible effect (in the statement footer). I’d try a complete reinstall, but the error is in the database records themselves. I made a half-hearted attempt to migrate my data to a new server, with a manual edit in between to remove the offending text, to no apparent effect.
Is it possible to create an update option similar to what’s available when changing Invoice template settings?
