When I check/select multiple invoices from the invoice table and then click “Download” I get the email with the download link but the file can’t be found.
I investigated a bit further and noticed that the temporary file is created on the public folder but is never moved to the right location to be download. I renamed that temp file to -invoices.zip and moved it to the right location and I was able to download it from the browser and the link send by email just fine so I assumed the problem is right after finishing the zip file and can’t be moved for some reason.
I couldn’t find any related error on the storage/logs/laravel.log file
Hello. The URL is clean, only the domain. The app resides under the public_html/invoiceninja folder and the apache was configured to direct the domain to public_html/invoiceninja/public as the root. The .env is configured as APP_URL=https://xxxx.xxxx.com
No as I have pointed the apache to use public_html/invoiceninja/public as the root of the virtual server for the specific domain. The thing is that I can’t find any error anywhere. Should be this somewhere logged? Also I have searched for the file just in case is misplaced because of the paths as you suggested but it doesn’t exists on the root folder
