Hi Guys,
I am trying to clean up our products list and wanted to know if I delete some products that are possible part of some payments/invoices break Invoiceninja, of affect the invoices/Payments in any way?
Also, there are instances that we need to create an invoice and set a product description or name as e.g: Foto Print - size 70x70, where the size should only be used for an invoice specifically, but it gets set in the product itself and we’d need to remember to remove this if we use the same product in anoher invoice that size is not required. Any way we can set these changes to the product to only apply in a given invoice instead of affecting the product permanently?
This would be nice as we’re a printing company that use different sizes depending on customer’s request, and creating the same product with difference in just the size is a bit annoying.
Thanks all
