Docker upgrade has broken IN v5 - docker compose issue
Version ie <v5.10.30> Can’t get access to check.. pulling latest.
Environment Docker
Checklist
  • Can you replicate the issue on our v5 demo site https://demo.invoiceninja.com or Invoice Ninja? No
  • Have you inspected the logs in storage/logs/laravel.log for any errors? No - error with docker-compose
Describe the bug
After an apt-get upgrade and then a docker compose down && docker compose pull && docker compose up -d the container fails to start with the error
Error response from daemon: could not parse extra host IP 192.168.0.124 : ParseAddr("192.168.0.124 "): unexpected character (at " ")
Steps To Reproduce
As above.
Expected Behavior
The container to start with no errors.
Additional context
The most recent docker related packages that have been upgraded according to the logs are:
containerd.io:arm64 (1.7.24-1, 1.7.27-1)
docker-buildx-plugin:arm64 (0.19.3-1~debian.12~bookworm, 0.23.0-1~debian.12~bookworm)
docker-ce-cli:arm64 (5:27.4.1-1~debian.12~bookworm, 5:28.1.1-1~debian.12~bookworm)
docker-ce-r ootless-extras:arm64 (5:27.4.1-1~debian.12~bookworm, 5:28.1.1-1~debian.12~bookworm)
docker-ce:arm64 (5:27.4.1-1 ~debian.12~bookworm, 5:28.1.1-1~debian.12~bookworm)
docker-compose-plugin:arm64 (2.32.1-1~debian.12~bookworm, 2.35.1-1~debian.12~bookworm)
Relevant part of docker-compose:
version: '3.7'
services:
  server:
    image: nginx
    restart: always
    env_file: env
    volumes:
      # Vhost configuration
      #- ./config/caddy/Caddyfile:/etc/caddy/Caddyfiledocker-com
      - ./docker/app/public:/var/www/app/public:ro
    depends_on:
      - app
    # Run webserver nginx on port 80
    # Feel free to modify depending what port is already occupied
    ports:
      - "7070:80"
      #- "443:443"
    networks:
      - invoiceninja
    extra_hosts:
      - "in5.localhost:192.168.0.124 " #host and ip
 app:
    env_file: env
    restart: always
    volumes:
      - ./config/php/php.ini:/usr/local/etc/php/php.ini
      - ./config/php/php-cli.ini:/usr/local/etc/php/php-cli.ini
    depends_on:
      - db
    networks:
      - invoiceninja
    extra_hosts:
 db:
#    image: mysql:8
#    When running on ARM64 use MariaDB instead of MySQL
    image: mariadb:10.4
#    For auto DB backups comment out image and use the build block below
#    build:
#      context: ./config/mysql
    ports:
      - "3305:3306"
    restart: always
    env_file: env
    volumes:
      - ./docker/mysql/data:/var/lib/mysql:rw,delegated
      # remove comments for next 4 lines if you want auto sql backups
      #- ./docker/mysql/bak:/backups:rw
      #- ./config/mysql/backup-script:/etc/cron.daily/daily:ro
      #- ./config/mysql/backup-script:/etc/cron.weekly/weekly:ro
      #- ./config/mysql/backup-script:/etc/cron.monthly/monthly:ro
    networks:
      - invoiceninja
    extra_hosts:
Screenshots
N/A
Logs
N/A
There appears to be a space in the above mentioned lines which has previously been parsed correctly - and now it is not. Editing the compose file to remove the spaces gives me an nginx 500 server error - and im unsure where these variable are called to change them.
Any ideas to help?
Nick
