Docker - SQLSTATE[HY000] [2002] No such file or directory
I hope someone can help me with setting up Invoice Ninja. I am new to using it, so I must be missing some step. It looks like an amazing app, but I am stuck and don’t know how to proceed.
I am trying to startup Invoice Ninja using Docker Compose, but seem to have a MySQL connection problem:
The MySQL instance is hosted remotely and is currently hosting various databases that are accessible by the Docker host and containers.
Using DBeaver from my local machine I can:
  • can connect to the Invoice Ninja database directly via DBeaver and used the grant option when creating the MySQL user and database.
  • create a table as the user and do a select via DBeaver .
  • connect to the MySQL remote DB from within the container.
  • see MySQL errors already when running “php artisan key:generate --show”. I assume this is correct since this has no MySQL config etc.
  • see that env vars are present inside the container.
…yet I still get these MySQL errors.
During my install, I created the keys using Artisan, then set up the compose file.
Debug Info
The select command from DBeaver:
SHOW TABLES
Tables_in_ninja
NewTable
The connection from the container to MySQL:
~ $ mysql -h 13.13.13.13 -u ninja -pninja123 ninja
Reading table information for completion of table and column names
You can turn off this feature to get a quicker startup with -A
Welcome to the MariaDB monitor.  Commands end with ; or \g.
Your MySQL connection id is 1235069
Server version: 8.0.21 Source distribution
Copyright (c) 2000, 2018, Oracle, MariaDB Corporation Ab and others.
Type 'help;' or '\h' for help. Type '\c' to clear the current input statement.
MySQL [ninja]> SHOW TABLES;
| Tables_in_ninja |
| NewTable        |
1 row in set (0.003 sec)
MySQL [ninja]>
SQL Command to Create User and Database:
CREATE USER 'ninja'@'%' IDENTIFIED BY 'ninja123';
CREATE DATABASE IF NOT EXISTS ninja CHARACTER SET utf8mb4 COLLATE utf8mb4_general_ci;
GRANT ALL PRIVILEGES on ninja.* to 'ninja'@'%' WITH GRANT OPTION;
FLUSH privileges;
I use the following compose example:
version: '2'
services:
  invoiceninja-app:
    container_name: invoiceninja-app
    image: "invoiceninja/invoiceninja"
    ports:
      - "61000:9000"
    hostname: "invoiceninja-app"
    environment:
     - IS_DOCKER=true
     - APP_ENV=production
     - APP_DEBUG=1
     - APP_URL=http://in-01.domain.com:61000
     - APP_KEY=base64:BZ5GN2QUAkiYEXAMPLEN9pq55jctXfAKX4=
     - APP_CIPHER=AES-256-CBC
     - DB_TYPE=mysql
     - DB_STRICT=false
     - DB_HOST=mysql-67.myhost.com
     - DB_DATABASE=ninja
     - DB_USERNAME=ninja
     - DB_PASSWORD=ninja123
    restart: "always"
    volumes:
     - /mnt/containers/invoiceninja-app-public/:/var/app/public/
     - /mnt/containers/invoiceninja-app-store/:/var/app/storage/
    networks:
      invoiceninja:
        ipv4_address: "172.37.0.4"
    logging:
      driver: "json-file"
      options:
        max-file: "1"
        max-size: "1m"
networks:
  invoiceninja:
    ipam:
      config:
        - subnet: "172.37.0.0/16"
Connections Inside Container
user@ip-200-262-81-70:~$ sudo docker exec -it invoiceninja-app /bin/sh
~ $ netstat -tlpn
netstat: showing only processes with your user ID
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
tcp        0      0 127.0.0.11:36559        0.0.0.0:*               LISTEN      -
tcp        0      0 :::9000                 :::*                    LISTEN      78/php-fpm.conf)
Docker Host Networks
user@ip-200-262-81-70:~$ sudo docker network ls
NETWORK ID          NAME                               DRIVER              SCOPE
5def5exc1fd2        invoiceninja_default               bridge              local
7433aurdc010        invoiceninja_invoiceninja          bridge              local
MySQL User Auth
SELECT user,authentication_string,plugin,host FROM mysql.user WHERE user="ninja";
| user             | authentication_string                     | plugin                | host      |
| ninja            | ssssssss                                  | mysql_native_password | %         |
Environment Vars In Container
~ $ env
SNAPPDF_EXECUTABLE_PATH=/usr/bin/chromium-browser
DB_TYPE=mysql
PHP_EXTRA_CONFIGURE_ARGS=--enable-fpm --with-fpm-user=www-data --with-fpm-group=www-data --disable-cgi
APP_DEBUG=1
HOSTNAME=invoiceninja-app
PHP_INI_DIR=/usr/local/etc/php
SHLVL=1
HOME=/var/www/app
DB_DATABASE=ninja
PHP_LDFLAGS=-Wl,-O1 -pie
PHP_CFLAGS=-fstack-protector-strong -fpic -fpie -O2 -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64
PHP_VERSION=7.4.15
DB_USERNAME=ninja
GPG_KEYS=42670A7FE4D04C074A4EF02D 5A528B46F53EA312
PHP_CPPFLAGS=-fstack-protector-strong -fpic -fpie -O2 -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64
PHP_ASC_URL=https://www.php.net/distributions/php-7.4.15.tar.xz.asc
INVOICENINJA_VERSION=5.1.13
BAK_PUBLIC_PATH=/var/www/app/docker-backup-public/
PHP_URL=https://www.php.net/distributions/php-7.4.15.tar.xz
TERM=xterm
INVOICENINJA_USER=invoiceninja
PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
BAK_STORAGE_PATH=/var/www/app/docker-backup-storage/
IS_DOCKER=true
APP_ENV=production
APP_KEY=base64:BZ5GNEXAMPLEjctXfAKX4=
PHPIZE_DEPS=autoconf            dpkg-dev dpkg           file            g++             gcc             libc-dev                make            pkgconf                 re2c
PWD=/var/www/app
PHP_SHA256=9b859c65f0cf7b3efb3c20d874a79b5ec44d43cb8
DB_STRICT=false
LOG=errorlog
Docker Log When Getting Key
user@server:~$ sudo docker run --rm -it invoiceninja/invoiceninja php artisan key:generate --show
Configuration cache cleared!
Configuration cached successfully!
Route cache cleared!
Routes cached successfully!
Files cached successfully!
In Connection.php line 678:
  SQLSATE[HY000] [2002] No such file or directory (SQL: select * from information_schema.tables where table_schema = ninja and table_name = accounts and table_type = 'BASE TABLE')
In Exception.php line 18:
In PDOConnection.php line 38:
base64:3t62u5g3ZebNLhIngSIU0mExu+FWSqMcekwWBhNfvnc=
Docker Container Log
  SQLSTATE[HY000] [2002] No such file or directory (SQL: select * from inform
[02-Mar-2021 09:21:58] NOTICE: [pool www] 'user' directive is ignored when FPM is not running as root
[02-Mar-2021 09:21:58] NOTICE: [pool www] 'group' directive is ignored when FPM is not running as root
[02-Mar-2021 09:21:58] NOTICE: fpm is running, pid 79
[02-Mar-2021 09:21:58] NOTICE: ready to handle connections
SQLSTATE[HY000] [2002] No such file or directory usually means something’s wrong with connection to host.
Are you able to ping your host using TCP from container? Also, can you try the default database from docker-compose just for the sake of testing? Thanks.
Thanks for getting back to me. I think I don’t understand something. Can you explain how running: “docker run --rm -it invoiceninja/invoiceninja php artisan key:generate --show” would not result in a SQL error, since the command contains no SQL info? Sorry if it’s a silly question.
I setup a local MySQL as well for testing and still get the same error with Invoice Ninja.
I can connect to the remote as well as local MySQL instance from inside the container - ping the private ip:
root@ip-172-27-8-7:/home/ubuntu# docker exec -u 0 -it invoiceninja-app /bin/sh
/var/www/app # ping 172.27.8.7
PING 172.26.8.7 (172.27.8.7): 56 data bytes
64 bytes from 172.27.8.7: seq=0 ttl=64 time=0.104 ms
64 bytes from 172.27.8.7: seq=1 ttl=64 time=0.112 ms
From inside the container - *ping disabled but the ip resolves) the MySQL instance:
/var/www/app # ping mysql-01.myhost.guru
PING mysql-01.myhost.guru (14.57.161.104): 56 data bytes
Note I can connect to my remote MySQL instance from inside the container:
/var/www/app # mysql -h mysql-01.myhost.com -u ninja -pninja123 ninja
Your MySQL connection id is 1957626
MySQL [ninja]> show tables;
| Tables_in_ninja |
| NewTable        |
From inside the container to the local MySQL container:
root@ip-172-26-8-7:/mnt/containers# docker exec -u 0 -it invoiceninja-app /bin/sh
/var/www/app # mysql -h invoiceninja-db -ptest
Your MySQL connection id is 10
Server version: 8.0.23 MySQL Community Server - GPL
MySQL [(none)]> show schemas;
| Database           |
| information_schema |
| mysql              |
| performance_schema |
| sys                |
4 rows in set (0.002 sec)
@david can you help with this? I don’t think there’s any special thing going on with external IPs?
I’m not an expert with docker, so hard to know what to suggest. As soon as the dockerfile is changed from standard it is very hard to help.
I am now running my Docker run just like the example provided AND can prove that I can connect to the MySQL db from within the container. There is nothing special here.
Can you show me an example of yours using Docker?
docker run -d \
  -v /var/invoiceninja/public:/var/app/public \
  -v /var/invoiceninja/storage:/var/app/storage \
  -e APP_ENV='production' \
  -e APP_DEBUG=0 \
  -e APP_URL='http://ninja.dev' \
  -e APP_KEY='base64:Qs7h2EtHleBdaLR+FsAKrBXtDAkzfzPKRfDDgTnxZSA=' \
  -e APP_CIPHER='AES-256-CBC' \
  -e DB_TYPE='mysql' \
  -e DB_STRICT='false' \
  -e DB_HOST='mysql-01.myhost.com' \
  -e DB_DATABASE='ninja' \
  -e DB_USERNAME='ninja' \
  -e DB_PASSWORD='ninja123' \
  -p '9321:9000' \
Connect to MySQL within the container:
ubuntu@ip-172-26-8-7:~$ sudo docker exec -it sharp_lewin /bin/sh
~ $ mysql -h mysql-01.myhost.com -u ninja -pninja123 ninja
Your MySQL connection id is 3824725
| Tables_in_ninja |
| NewTable        |
MySQL [ninja]>
In you’re pulling down version 5 in your docker compose then the environment variables have been changed to all need a 1 at the end, e.g DB_USERNAME1 etc.
You can see the code at invoiceninja/database.php at v5-stable · invoiceninja/invoiceninja · GitHub
There’s a double env in there but I don’t think that works as changing the environment variables fixed the problem for me
Thanks for sharing this!
cc @david
I’ve deployed the latest docker image into my local docker desktop and i’m stuck with this same error msg on the initial setup page, when testing my database connection. I also noticed the database name it suggests differs from the default .env file:
Aside from maybe change the db name to ‘ninja’, i’m not sure what else could be going on. Thoughts? I read the above and the linked ticket as well but they seem so old now i wasn’t sure if i should dive into their suggestions just yet or if they’re still relevant.
NEVERMIND; i answered it myself by reading it over again. change host to ‘mysql’ and db name to ‘ninja’. i passed that test now.
oops, but then it failed here:
The command “mysql --user=”${:LARAVEL_LOAD_USER}" --password=“${:LARAVEL_LOAD_PASSWORD}” --host=“${:LARAVEL_LOAD_HOST}” --port=“${:LARAVEL_LOAD_PORT}” --database=“${:LARAVEL_LOAD_DATABASE}” < “${:LARAVEL_LOAD_PATH}”" failed.
Exit Code: 1(General error)
Working directory: /var/www/html/public
Output:
Error Output:
ERROR 2026 (HY000): TLS/SSL error: self-signed certificate in certificate chain
