I’ve been trying to get out of the initial setup page for days, and I can’t. It’s driving me crazy.
[2020-12-01 20:20:54] production.INFO: The command “mysql --user=”${:LARAVEL_LOAD_USER}" --password="${:LARAVEL_LOAD_PASSWORD}" --host="${:LARAVEL_LOAD_HOST}" --port="${:LARAVEL_LOAD_PORT}" --database="${:LARAVEL_LOAD_DATABASE}" < “${:LARAVEL_LOAD_PATH}”" failed.
Exit Code: 1(General error)
Working directory: /var/www/app/public
Output:
Error Output:
ERROR 1050 (42S01) at line 9: Table 'accounts' already exists
In fact, I got it once, but I deleted the docker-compose and I don’t know what is going wrong for me.
Please help.
version: '3.7'
services:
server:
image: nginx
restart: always
environment:
- APP_URL=https://192.168.100.252
volumes:
# Vhost configuration
# Configure your mounted directories, make sure the folder 'public' and 'storage'
# exist, before mounting them
#- public:/var/www/app/public
#- storage:/var/www/app/storage
# you may use a bind-mounted host directory instead, so that it is harder to accidentally remove the volume and lose all your data!
- ./public:/var/www/app/public:rw,delegated
- ./storage:/var/www/app/storage:rw,delegated
depends_on:
- app
# Run webserver nginx on port 80
# Feel free to modify depending what port is already occupied
ports:
- "10080:80"
- "10443:443"
networks:
- invoiceninja
app:
restart: always
cap_add:
- SYS_ADMIN
environment:
- APP_KEY=base64:569LzoP3jBJHHvB8CnD/R/UuhpDQ7TA0k7amk1FT73c=
- MULTI_DB_ENABLED=false
- DB_HOST1=db
- DB_USERNAME1=ninja
- DB_PASSWORD1=ninja
- DB_DATABASE1=ninja
- PHANTOMJS_PDF_GENERATION=false
volumes:
depends_on:
- db
networks:
- invoiceninja
db:
image: mysql:5
restart: always
environment:
- MYSQL_ROOT_PASSWORD=ninjaAdm1nPassword
- MYSQL_USER=ninja
- MYSQL_PASSWORD=ninja
- MYSQL_DATABASE=ninja
volumes:
- mysql-data:/var/lib/mysql:rw
# - ./docker/mysql/data:/var/lib/mysql:rw,delegated
networks:
- invoiceninja
# THIS IS ONLY A VALID CONFIGURATION FOR IN 4. DO NOT USE FOR IN 5.
# cron:
# image: invoiceninja/invoiceninja:alpine-4
# volumes:
# - storage:/var/www/app/storage
# - logo:/var/www/app/public/logo
# - public:/var/www/app/public
# entrypoint: |
# /bin/sh -c 'sh -s <<EOF
# trap "break;exit" SIGHUP SIGINT SIGTERM
# sleep 300s
# while /bin/true; do
# ./artisan ninja:send-invoices
# ./artisan ninja:send-reminders
# sleep 1d
# done
# EOF'
# networks:
# - invoiceninja
volumes:
mysql-data:
public:
storage:
# This is needed for letting th cron run correctly
# logo:
networks:
invoiceninja:
