Is there a docker compose config file or setup that we could use to deploy IN on an environment that already has a nginx and a DB Server? We basically want to use our own DB and proxy server, instead of having new ones deployed by IN on install.
I i’ve tried the steps here and tried removing the DB and proxy lines but nothing work, or i am missing something.
I’m not an expert in Docker. but if you want to use your own nginx frontend, you’ll need to still somehow forward the requests from nginx to the Invoice Ninja container PHP process, and I can’t think of a way to do this without using nginx inside the invoice ninja container to reverse proxy those requests to the PHP process.
Hello, I found a solution for this for anyone like me who already have nginx / mysql running for other apps and don’t want to bother manual install with php configuration etc…
Create a network in docker (ninja for example) and find the ip something like 172.24.0.1 the container ip will be 172.24.0.2.
Create a docker container with this https://hub.docker.com/r/invoiceninja/invoiceninja
I’m using portainer but it’s the same as command line, be sure to map volume correctly and on your host set permissions to the folders to user 1500.
Assign it to ninja network.
Add extra host
host.docker.internal:host-gateway
Complete all .env and in mysql IP use host.docker.internal
In nginx on your host create a website and for the php configuration use this (replace CONTAINER_IP with yours, in my case it was 172.24.0.2)
