inhv
October 2, 2016, 8:02pm
1
Hi Hillel,
I’ve just updated a container to version 2.7.2 via the following commands:
docker-compose stop
docker-compose pull
docker-compose rm
docker-compose up -d
I had this container working successfully just prior with 2.7.1 having upgraded from an older version.
Now on starting, the APP container reports the following SQL errors in the logs:
Running DatabaseSeeder
[Illuminate\Database\QueryException]
SQLSTATE[23000]: Integrity constraint violation: 1062 Duplicate entry '0-1' for key 'payment_terms_account_id_public_id_unique' (SQL: insert into <code>payment_terms</code> (<code>num_days</code>, <code>name</code>, <code>public_id</code>, <code>updated_at</code>, <code>created_at</code>) values (7, Net 7, 1, 2016-10-03 06:40:39, 2016-10-03 06:40:39))
[PDOException]
And so the APP container will not start now…
Any clues please on how to fix this?
October 4, 2016, 9:47am
It looks like the app is running the ConstantsSeeder which should only be run when the app is first installed.
Maybe this post will help?
https://www.invoiceninja.com/forums/topic/2-7-1-update-for-docker-broken/#post-4284
inhv
October 4, 2016, 8:47pm
3
Hi Hillel,
That doesn’t help me… I wrote that post. I had upgraded from a much older version using the technique above but with 2.7.1 to 2.7.2 it’s giving me that SQL error…
Full log entry here - it happens on trying to restart too:
MySQL ready
Generating optimized class loader
Compiling common classes
Nothing to migrate.
SQLSTATE[23000]: Integrity constraint violation: 1062 Duplicate entry ‘0-1’ for key ‘payment_terms_account_id_public_id_unique’ (SQL: insert into payment_terms
(num_days
, name
, public_id
, updated_at
, created_at
) values (7, Net 7, 1, 2016-10-05 07:52:29, 2016-10-05 07:52:29))
[PDOException]
October 4, 2016, 8:50pm
4
It looks like you’re running the DatabaseSeeder, that should only be run when first installing the app. After an upgrade you need to run UpdateSeeder.
lalop
October 5, 2016, 3:55am
5
I added some databaseseed into the entrypoint of the docker image last week to fix some issue while seeding the database via web request.
That create a regression for upgrade, I comment this new feature temporarily in the docker image and I will try to find a better solution.
Hillel a push a first pr on invoiceninja let me know if this is going on a good way.
https://github.com/invoiceninja/invoiceninja/pull/1094
inhv
October 5, 2016, 6:29pm
6
Hi all,
I just did a fresh docker pull since I see it has been updated. It hasn’t resolved the problem. Is there a way to pull the 2.7.1 version? The only Docker tags available since 2.5.1.2 is ‘latest’…
e.g. here - https://hub.docker.com/r/invoiceninja/invoiceninja/tags/
thanks,
Harry
lalop
October 6, 2016, 6:05am
7
I stoped to tag the image since I started to use automated build.
The only way to have the 2.7.1 is to download this https://github.com/invoiceninja/dockerfiles/archive/f53573d200ce9ab6fe9dadf279e19277eef59f99.zip and build your own image with docker
inhv
October 6, 2016, 2:31pm
8
OK. is a fix coming for the problem instead?
lalop
October 12, 2016, 1:40pm
9
Yes the last image should work for you
inhv
October 12, 2016, 8:02pm
10
thanks very much. That has fixed it. There’s a new issue with the CRON failing now but I’ll create a new thread.
lalop
October 13, 2016, 4:20am
11
