xisonc
1
Hi there,
Perhaps I’m missing something, but is it possible to display the currency code of the invoice on the PDF invoice?
We bill in USD and CAD, where the symbol is the same, so I would like it to indicate the currency code on each PDF invoice.
I’ve looked at creating a custom template, but I don’t see a variable I can pull in that provides this.
Thoughts? Tips?
Thanks!
xisonc
Alright, so, dumb me. I found under Localization the ability to switch between Currency Symbol and Code.
I switched it to Currency Code, which is fine.
I do think it would be cool to have the option to show both. Curious if anyone’s figured that out?
Thanks.
3
Showing both isn’t currently supported, feel free to create an issue on GitHub to request it.
