as title, there’s a way to do that? i only need to be able to send it manually
Note: You can select a category when creating issues to specify.
the docker one, just updated to 5.1.14
sorry for the missing tag
Thanks! You can disable the emails on Settings > Company Details > Defaults
thanks so much! now i remember i enabled that when i started thinkering before the production env
one more thing regarding the Settings > Company Details section:
In the address tab i can’t remove the country field, when i click on the X to it’s right and then save, the field it’s filled with the default “United States”
regarding emails, i’ll ask another question here without opening another thread to avoid cluttering:
how can i disable the confirmatory “invoice X was sent to” emails that are sent out to my admin email everytime i mark an invoice as paid or when an invoice is sent manually to clients?
I’ll look into the country issue
You can configure your user email on Settings > User Details > Notifications
i disabled all notification but still receive “Payment was made by” when i mark an invoice as paid
another question (can’t create another thread about right now):
how can i download bulk invoices? when i select multiple invoice, on the actions menu i can see only send, archive and delete options
If you think it’s broken feel free to report a bug:
v5 doesn’t currently support bulk downloading PDFs
