Can anyone help me with directions on how to upgrade my self-hosted Invoice Ninja from V4.5.19 to V4.5.21. I used the zip file (not the Github file) for the initial installation.
Thanks, Julius
Thanks, Julius
Thanks! Just curious about this part when going from v4.5.xx to v4.5.xx:
To update the app you just need to copy over the latest code. The app tracks the current version in a file called version.txt, if it notices a change it loads /update to run the database migrations.
Would this still be true with a Softaculous upgrade? In other words, if I installed via Softaculous and upgrade via Softaculous - would it overwrite version.txt (and mess up the database update) or will it leave that file alone so things will work as planned with the database?
Not sure I understand your question, the update works correctly with Softaculous.
Okay, great to know. Thank you.
I think I was curious if I updated via Softaculous, if it would forget to update the database (if necessary) between versions.
