I have a couple of French clients that I bill in Euros, and a month ago (running a slightly earlier version, 4.4.1 of invoice ninja) the amount was properly represented to them everywhere in the Invoice Ninja interface and on the PDF invoice as:
1.400,00 € (that is one thousand four hundred euros and zero euro cents, with the euro symbol after a space and at the end)
But today I issued a new invoice to my other French client with the same settings (Euro currency, French langage) while on updated 4.4.3 and it is suddenly looking like this everywhere:
€1,600.00 (that is one thousand six hundred euros and zero euro cents, with the euro symbol at the beginning with no space after)
Is there some reason this might have changed or some way to set the proper formatting for my French clients?
The country is definitely set. Can you tell me where the currency formatting settings for each language are stored? I can check there and manually edit them I guess. Thanks!
Well this is very strange. In each of my French clients I have currency dropdown set to “Euro” and Language set to “French” (not “French - Canada” btw) and in every invoice I create for any of them, the formatting is not what it what a month ago. The currency symbol is placed before the amount, and the separators are wrong (comma and period should be reversed). Any other ideas? I have verified that my CountriesSeeder.php file looks like yours linked to above btw.
I’m a new french user of InvoiceNinja.
I have clients in Martinique.
Martinique and Guadeloupe are French islands.
But, the first client I just recorded in Martinique is left with the sign € before the amount rather than after …
I tried to add these lines to the CountriesSeeder.php file:
‘MQ’ => [// Martinique
‘swap_postal_code’ => true,
‘swap_currency_symbol’ => true,
But, that does not work.
Can you tell me how to correctly display the amounts for my clients in Martinique?
Thank you in advance. and sorry for my bad english…
