Is there a way to use a real invoice to make a new design ?
or where can we change the sample client invoice data which is used for designing the invoicetemplate?
I’m not sure I understand “use a real invoice to make a new design”.
We don’t currently support changing the sample data.
Hi the sample data doesn’t have data for all fields like vatnumber identificationnumer etc
if i use $clientIdNumber or $clientVatNumber i don’t see anythiung
You’d need to test those fields with an actual invoice.
Note: the variables are $client.idNumber and $client.vatNumber
tx
question
how is formatting used in tables ?
$firstAndLast
where can we see how the formatting is done ?
For example: "hLineWidth":"$firstAndLast:.5",
would set the horizontal line width for the first and last rows to .5.
Here’s the code for PDF generation: https://github.com/invoiceninja/invoiceninja/blob/master/resources/assets/js/pdf.pdfmake.js
