Hi guys - I recently had an issue with email not sending, which was resolved. However many of the invoices that were emailed subsequently had to be resent.
Is there any way I could implement a delivery receipt notification? - Would offer some peace of mind that email is actually delivered successfully to clients.
I’ve setup a Postmark account now - and have made the modifications to the settings as outlined in your guide.
In my .env I have commented out all mail related lines, except for MAIL_FROM_ADDRESS= and POSTMARK_API_TOKEN= - however it doesn’t work - no email is sent and the logs show
I presume the Postmark API in my .env should be set to to the Postmark server API? - I’ve tried using both server and account API keys - no difference however.
I’ve commented out all ‘mail related’ settings in .env… a tad vague though, which settings specifically?
Is the email sent? The line of code is failing because the response doesn’t include MessageID, enabling the feature with Postmark should cause the value to be returned.
Open tracking has been enabled from the start… the email never reaches the recipients. If I switch back to normal SMTP in my .env, email works again - just refuses to with Postmark.
