Delivery Note Design
When in: Settings >> Invoice Design >> General Settings
There is a field labelled: Delivery Note Design
But the dropdown is empty - how can I populate it?
I am looking to:
  • modify the current delivery note with some custom fields
  • create a second delivery note to use as a picking list with additional columns
If I assume correctly then this can be done with custom templates.
Can you point me to where to find the current delivery note layout and how to duplicate it, please?
I believe you’d need to create a new delivery note template.
Trying to follow the guide but there seems to be a bug:
In invoice design, selecting any option:
Always goes back to the same screen:
Unless the tutorial is incorrect?
I suggest trying with the mobile app to see if there’s a difference.
Yes, that works, thanks.
Is there any way to access the demo site with the mobile app? I am testing pro customisations before purchasing and wanted to test on the mobile as well as the desktop.
Feel free to create an issue on the web GitHub repo:
You can use these selfhost credentials to login with the mobile app to the demo site.
Done: Dropdown empty on web browser · Issue #9903 · invoiceninja/invoiceninja · GitHub
You truly are a wealth of information. How did I miss that? Thank you again.
