Deleting permanently the unnecessary data at deleted section
Hi how can I delete the unnecessary data at the deleted section. Thank you
You can purge a client to remove them from the deleted list.
There’s also an option to purge all data on Settings > Account Management.
Thanks, it helpful, I have another question: is it okay if we use three different devices in one account?
A single person can use multiple devices (ie. desktop and mobile) however if it’s separate people we recommend using an enterprise plan where each person has their own login.
hi do you have users manual ?
The docs are available here: https://invoiceninja.github.io/
Do you have other ways to delete all permanently at once instead of using purge one by one? It takes a lot of time.
You can purge all data on Settings > Account Management.
