first of all, I would like to thank you for the GREAT work you are doing !
I have a little issue :
I created an invoice with a specific number which I later deleted.
I wanted to edit a new invoice with the same number but it was impossible.
Is there a way to delete the invoice permanently from the system ?
Thanks a lot for your help.
O.
ps : by the way, I can translate in French and in Dutch if needed. I have to invoice to several languages so…
Thanks for your answer.
But…
I’m really not the king as it comes to mysql database editing …
I tried to use mysql workbench on ubuntu, I found the query “invoice_number” but I could not modify anything as it appears to be read-only. I tried with the root account aswel. I then update the user permission on the ninja user but still didn’t get any luck …
Could you please help ?
Thanks in advance.
O.
