Default Task Status is Done instead of Backlog
Version: v5.13.22
Environment: Docker
Checklist
  • Can you replicate the issue on our v5 demo site Invoice Ninja? Yes
  • Have you inspected the logs in storage/logs/laravel.log for any errors? No
Describe the bug
Newly created tasks (even without tracked time) have the default status Done.
Steps To Reproduce
  1. open the React app
  2. click on “Tasks” » “New Task”
  3. see the field “Status”, the value is Done
Expected Behavior
Default Status should be Backlog or maybe In progress but not Done.
Screenshots
Bug or Misconfiguration?
I’m not sure if this is a bug or a misconfiguration, but I didn’t found a setting for the default task status.
If you haven’t created much data yet you may be able to rename the statuses to correct this.
Feel free to create an issue on GitHub to track this:
You mean rename DoneBacklog and BacklogDone?
What do you mean with “If you haven’t created much data yet”?
Because all currently Done tasks after that change are in status Backlog?
If that’s the case, then with over 700 existing tasks, it’s not feasible.
In that case I suggest asking on GitHub
